Callaway Honker installed
Old Oct 7, 2006 | 03:52 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Something I've been curious about... In a dyno situation, with little or no air flowing into the front of the car, the fans will be on the majority of the time. Now, with the fans on, they will be trying to pull air from anywhere and create somewhat of a vacuum in the area where the honker pulls air from. Would the fans not try to pull air from the honker itself, thereby robbing air meant for the intake system?
Old Oct 7, 2006 | 04:43 PM
vettenuts's Avatar
vettenuts
At the dyno facility that tuned my car, they run a huge fan in front of the car to help cool things down. Also, after a couple of runs, they let the car cool for a period of time as well.
Old Oct 7, 2006 | 05:06 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Does this uint require a hole to be cut in the radiator shroud?
Old Oct 7, 2006 | 05:15 PM
gja's Avatar
gja
yes
Old Oct 7, 2006 | 06:48 PM
Frankie2blue's Avatar
Frankie2blue
Which is no big deal. If you ever want to go back, they cost about 50.00 at the dealer and about 45 minutes tops to change out. And having the Calllaway name anywhere on your car is not a bad thing!
Old Oct 7, 2006 | 09:11 PM
3cRider's Avatar
3cRider
7th Gear
I'm trying to decide between the Honker and the VaraRam but wish someone would do back to back comparos of them to see which nets better dyno and track numbers.
Old Oct 7, 2006 | 09:17 PM
jdmvette's Avatar
jdmvette
Night Owl for life
the way i looked at it when deciding on the intakes was that if the honker makes 99.5% of the power of the vararam, but has 100x more fit and finish quality, why choose something that makes a smidge more power but fits like junk?
Old Oct 7, 2006 | 09:40 PM
Z06ufgrad2002
Originally Posted by gja
yes
I also notice it has a convoluted air bridge which in most case folks replace the OEM piece with a smooth coupler.
Is the Callaway piece smooth in the interior of the air bridge portion of the ducting?
Old Oct 7, 2006 | 11:03 PM
jdmvette's Avatar
jdmvette
Night Owl for life
yes. see mcv's other posts to confirm.
Old Oct 8, 2006 | 02:54 AM
Dirty Howie's Avatar
Dirty Howie
Have any of you guys cleaned your Honker filters yet ??
How long did it take, do you have to remove the coupler/MAF, how long did it take for filter to dry before oiling......
DH
Old Oct 8, 2006 | 10:35 AM
Darion's Avatar
Darion
Default Architect, you call BS, how would you know?
Went for a ride yesterday and feel the Honker is well worth the cost and time to install. Rev range pulls very strong, second feels great and forth pulls much cleaner. Hard first to second shift still had hop but I think that may be due to my base suspension from what I read. Base suspension will go away this winter for upgraded parts and see what happens.
Have a great weekend to all,
Darion
Old Oct 8, 2006 | 11:55 AM
'VETTE PHASE
The point I was trying to make was that this guy is claiming a 36 hp gain by simply changing to a different aftermarket breather system. The biggest claim to fame for his system is the ram air effect and the cooler air from in front of the radiator. A lot of people cut out the scoops where the fog lights are to get cool air to their aftermarket breathers, so there is no real advantage there. The only thing left is the ram air effect which, even with a fan blowing in the general area of the front end, has no real effect on a dyno. And since the fans on the car are probably running, there is the possibility of taking air away from the intake area, as the fans are pulling directly throught the radiator in direct line with the intake area, furthter decreasing the ram air effect.
All this, and still making 36 hp. Imagine if it was working correctly and you could tune it with the actual amount of air that comes into it at xx mph. It would probably make 60+ hp.
Old Oct 8, 2006 | 01:19 PM
  #33
Z06ufgrad2002
DH
I'd like to know the answers to these ?'s as well.
Also, does anyone have a good pic of the filter element?
Old Oct 8, 2006 | 02:18 PM
  #34
Darion's Avatar
Darion
Well, I just put mine in so I can't say about cleaning. But, I did find this pic
As for removal of the filter, I would say it would be easiest to remove the coupler/MAF to get it out. This really isn't a bad job though, wouldn't take more than a few min. to get out and re-install.
Darion
Old Oct 8, 2006 | 06:56 PM
  #35
ErnieN85's Avatar
ErnieN85
DH
I cleaned mine this weekend. Took it out Friday night. Cleaned it let it dry overnight, reoiled and assembled it Sat Am. How long well Fri Pm about 15 twenty min to disassemble & clean, Sat I cleaned the radiator changed the oil and waxed the car and reassembled by noon. I was going to change the plugs 75,000 on the denso iridiums but they looked like new and the gap wasn't worn....... so I didn't bother!
Old Oct 8, 2006 | 08:16 PM
  #36
kingsey's Avatar
kingsey
Is your car a daily driver? if it is would you still have the stinger on it compaired to the honker.
Old Oct 8, 2006 | 09:13 PM
  #37
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
DH
Howard, to remove the Honker / air filter for cleaning..
1. unscrew and remove all 4 fasteners on the air filter frame.
2. loosen (not necessary to remove) the band clamp holding the oval rubber bridge to the filter housing.
3. loosen (not necessary to remove) the clamp holding the rubber coupler to the throttle body.
4. unhook the connector for the MAF and if 97-2000 the air temp sensor.
5. pull back and lift up on the rubber coupler on the throttle body end.
6. you can now slide the whole assembly back and up, un-hooking the tabs on the front of the air filter frame.
7. pull the filter out, clean, dry, re-oil, installation is reverse of removal (well, almost; after slipping the coupler back onto the throttle body and seating everything, I re-install the 4 filter frame screws, make my way back tightening the clamps).
To Callaway Honker installed
Old Oct 8, 2006 | 09:58 PM
  #38
Darion's Avatar
Darion
My car is not a daily driver. If it were I'm not sure I would have put in a CAI at all, most likely I would not have. I live in NE Ohio and at times the rain is very hard and standing water is an issue. The standing water would be my biggest concern for hydrolock and sometimes you cant see it or avoid it.
I responded to your PM I hope that helped.
Darion
Old Oct 8, 2006 | 10:02 PM
  #39
MUKAK's Avatar
MUKAK
Originally Posted by Howard Wolf
I tried 3 different brands before installing the Callaway honker. Picked up 36 hp on the chassis dyno (with the hood closed). Biggest difference I noticed at the track was how much smoother it ran at the higher rpm's (6500+). Highly recommend it.
36 hp?!!??
gimme some of dat $hiT u smoking..
Old Oct 8, 2006 | 10:37 PM
  #40
Kappa's Avatar
Kappa
Originally Posted by MUKAKsC5
36 hp?!!??
His car is a heavily modified 427 mostly used for drag racing. Remember, he said hood closed. It could happen especially if he came from an intake like a Blackwing.
I've seen the car in person. It hooks like there's super glue stuck to the rear tires(1.3x 60' times).
