Spec Clutches equal JUNK!
Old Oct 17, 2006 | 03:00 AM
  #41
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
I will share my experience with Spec. I have had 3 of their clutches.
1st Spec stage 3. Great clutch, held around 650RWHP with no problems, did a great job while i had it. Switched becasue i turned up the boost to around 800RWHP
That led to the second clutch: The spec 3+. Was told how great this clutch was and it would hold the power. This was a piece of junk. It wouldn't hold what the 3 did. Lasted all of 200 miles before i junked it. Drove great though, better than the 3
That led to the clutch i have now Spec Twin Disk. Awesome clutch. Drives almost like stock, holds a lot of power (over 1K). The downside to this clutch i found is 2 fold. 1. It is a chattering SOB. Not at first, but after a few miles on the clutch, it started to chatter. I believe it is common with most twin disks. 2. The price 2000.00 for a clutch is a little much, but it holds like no other
Dom
Old Oct 17, 2006 | 08:28 AM
  #42
Billdog350's Avatar
Billdog350
Dom
Dom, so you're saying the SPEC 3+ that's rated for 850 CRANK tq should hold your ~800rwhp car? Isn't that like ~940crank hp? Also, if your torque is more than your hp as in most boosted vehicles...you're well over 1000ft lbs on a clutch rated for 850...
I'm considering the SPEC III+ for my ~450rwhp C5...in your opinion will it be a good setup? I'm looking for something VERY streetable without much chatter that will hold the hp. It sounds like I'll have HALF the hp as you....
Old Oct 17, 2006 | 09:13 AM
  #43
Darkness's Avatar
Darkness
Originally Posted by Billdog350
D
Forget it then, the spec 3+ will handle the power just fine but its not streetable like you want. Very on/off and lots of chatter.
Old Oct 17, 2006 | 09:29 AM
  #44
Billdog350's Avatar
Billdog350
Ok, I see that you have a SPEC III+ in your sig. How many miles on it? I've heard they chatter for ~500 mi and then quiet down quite a bit. Maybe the 2+? Those are supposed to be good for 620 tq which sounds like plenty.
Old Oct 17, 2006 | 11:47 AM
  #45
tlaselva's Avatar
tlaselva
Spec 3+ not streetable?
Try a Excedy Dual. That's not streetable!
Spec 3+ feels like stock in pedal feel, and was nice to be able to slip the clutch again after the Excedy.
Old Oct 17, 2006 | 11:57 AM
  #46
Jon Malis's Avatar
Jon Malis
Cruising
I had Spec in my GT - worked ok but eventually I couldn't power shift
Old Oct 17, 2006 | 01:21 PM
  #47
Mr. Big's Avatar
Mr. Big
The 3+ was a very streetable clutch, and i had no chatter at all. It was an awesome clutch, just wouldn't hold the power. I had better luck with the stage 3. It seems almost all clutches are hit and miss. Sometimes they hold, sometimes they don't.
Old Oct 17, 2006 | 02:22 PM
  #48
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I have a LUK stage II w/ a fidanza aluminum flywheel and the drill mod... I'm not a hardcore drag racer, but I have run 12.10's on street tires w/ it.
It's great for the road racing I do b/c the 14 lb. flywheel really allows the car to rev.
I went through a horrid balance nightmare though... nobody told me about the whole match balancing issues some of these cars can have. Install a perfectly good clutch only to find that your factory stuff was slightly off-balanced to compensate for the motor.
Old Oct 17, 2006 | 07:11 PM
  #49
Darkness's Avatar
Darkness
Not mine slim, it feels worse than a f'n truck. And it doesnt slip without shaking the crap out of my teeth fillings either.
Old Oct 17, 2006 | 09:59 PM
  #50
Billdog350's Avatar
Billdog350
Darkness, have you drag raced your car often or brake torqued at all? I'm trying to figure out why you have an issue and others are saying they're buttery smooth. Its obvious there are SPEC quality questions, but besides that, most people say that the SPEC III+'s are good...I'm always interested in the outliers...
Old Oct 17, 2006 | 10:17 PM
  #51
Darkness's Avatar
Darkness
No track launches on this clutch, just the usual weekend night street fun. 6k miles it lasted me though but it was heavy and chattery from day 1.
Old Oct 17, 2006 | 11:47 PM
  #52
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Like I said, I have Spec V, with a SPEC aluminum flywheel. I broke it in over with over 1,000 miles. No chatter and I can engage it at 1,200 rpm's. I do have a lot of torque.
Old Oct 18, 2006 | 01:09 AM
  #53
Mr. Big's Avatar
Mr. Big
This sound more like a singled out clutch. Maybe you just got a bad one, or there was a problem during install. I have put in 3 of those clutches now, (only 1 in my car) all were smooth
Old Oct 18, 2006 | 01:42 AM
  #54
DALE C's Avatar
DALE C
I have installed a ton of SPEC clutches the only problems I have had were with disengagment which was solved with a larger bore master cylinder. I have never had one slip. I have a stage 3 in my roadrace car with three seasons on it and another stage 3 in a 700 RWHP roadrace car with no problems
Old Oct 18, 2006 | 02:11 AM
  #55
heavychevy's Avatar
heavychevy
If my car can ever go 500 miles without being back in the shop I will let ya know but so far no problems from my SPEC. So far about 2k miles with the clutch on there, mostly on the dyno.
Old Oct 18, 2006 | 02:36 AM
  #56
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I LOVE my Cartek clutch!!! I have over 850rwtq and I it is by far the most streetable clutch I've owned. The pedal pressure is about 15% heavier than stock and you can slip it all day long.
I have beat the pi$$ out of this clutch and its flawless.
Old Oct 18, 2006 | 02:39 AM
  #57
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Hey Doug,
It doesnt count coming from you guys..
You could find a way to break a clutch that was made out of cromoly and unobtanium!!!
Originally Posted by DOUG @ ECS
Hey Jeff,
Several clutches (including yours) will spark when launched hard through the two holes on the bottom of the bell housing. I guess due to the types of materials used. I have seen that several times before on clutches that worked great for a long time afterwards. (although Spec has not worked for us either)
To Spec Clutches equal JUNK!
Old Oct 18, 2006 | 07:49 AM
  #58
Billdog350's Avatar
Billdog350
Yes, but I have a planned ~400-450 rwtq....Carteks are a bit overkill, financially and mechanically. If I knew it would be perfect and last me for ~50k miles, then I'd consider the Cartek but I have seen people say they aren't the best daily driver clutch for medium hp/tq cars.
Looking more and more like Spec III+...a few complaints but most people seem to have positive results (80%).
Old Oct 18, 2006 | 09:20 AM
  #59
1-BAD-C5's Avatar
1-BAD-C5
If you dont mind me asing how much did you pay for your cartek clutch and which one do you have from them.
Old Oct 18, 2006 | 09:31 AM
  #60
Darkness's Avatar
Darkness
I need to decide if I should just buy another 3+ and take a chance, or go with the cartek and know its going to hold fine with the nitrous.
