Brakes
Old Oct 27, 2006 | 08:34 PM
Blow Torch's Avatar
Blow Torch
Default Brakes
What brake pads are you guys using for DD C5s. My wife's car needs some new pads, and she doesn't need the super high performance, no fade, etc. etc. since she rearly gets the car over 80mph. (Of course I, on the other hand, have to "test" the mods we've done to it occasionaly, just to see if they still "perform" properly )
Old Oct 27, 2006 | 09:07 PM
JimmyZ78's Avatar
JimmyZ78
I was told by a reputable person with vettes that AC Delco's (Stock) are the only ones that are quiet. I bought some and am installing them tomorrow.
Old Oct 27, 2006 | 09:21 PM
fastdriver1's Avatar
fastdriver1
I've used Delco ceramic for years. Not a "high performance" pad but vitually dust free.
Love them!
Old Oct 27, 2006 | 09:22 PM
rws.1's Avatar
rws.1
AC/Delco Durastop Ceramic... from Fred Beans
Low dust, no squeal....
Old Oct 27, 2006 | 10:34 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
With the pads where to buy them.
Old Oct 28, 2006 | 07:11 AM
Blow Torch's Avatar
Blow Torch
Sounds like it should be Delco then. She definitly wants them to be quite Brakes on Vettes should NEVER squeal
Old Oct 28, 2006 | 08:30 AM
vettenuts's Avatar
vettenuts
I think the GM's also come with one new caliper bolt per wheel so you can just remove one bolt, rotate the assembly and then use the new bolt when done. Someone correct me if I am wrong, but that is how I remember it.
Old Oct 28, 2006 | 09:25 AM
patton's Avatar
patton
St. Jude Donor '09
yep 1 bolt and oem are my choice
Old Oct 28, 2006 | 10:35 AM
Barrier's Avatar
Barrier
Not to steal thread.
I purchased these and no bolt was included. The shims and clips were there but no Bolt? These are the GM Ceramics as well?
Where can I get the 2 bolts, Right & Left.
Barrier
Old Oct 28, 2006 | 12:53 PM
vettenuts's Avatar
vettenuts
You can either order them from GM or clean up your old ones and use loctite on them. The only difference with the new bolts is they have a thread locker pre-installed.
Old Oct 28, 2006 | 01:02 PM
PVHolgado's Avatar
PVHolgado
I have an extra set of the ceramics anyone needs them $100 shipped to lower 48- pvholgado@hughes.net
Old Oct 29, 2006 | 12:42 AM
Dave68's Avatar
Dave68
If you still have stock-type rotors, you might want to try something other than the OEM pads. Stock rotor + OEM pads = pulsating pedal because of uneven brake pad deposits on the rotors. I got tired of this issue and switched to slotted PowerSlot rotors - never had the problem again.
To Brakes
