catastrophic engine problem?
Old Nov 4, 2006 | 06:17 PM
BBQ's Avatar
BBQ
Default catastrophic engine problem?
I got under my car this afternoon. I was trying to troubleshoot what sounded like an exhaust leak. Well, I didn't find an exhaust leak. It appears this knocking sound is coming from inside the motor (toward drivers side)
No loss of power or other symptoms yet. What do you think?
Old Nov 4, 2006 | 06:25 PM
Blue02ws6's Avatar
Blue02ws6
If it is coming from the bottom, you prob spun a rod bearing. If so it will get much worse very soon. I ran into the same problem on mine and it's at TSP getting a 402 installed right now. There is always a bright side.
Old Nov 4, 2006 | 06:31 PM
TYSON1997's Avatar
TYSON1997
You would know a rod knock w/o ever even hearing one before. Mine has made noises since I got headers. If you have headers they are just louder than normal manifolds. Also those little donuts that couple the exhaust after manifolds always leak a little bit. Check oil pressure, change oil and cut open filter and look for metal. If oil is clean most likely not a rod. Try a thicker oil and see if it changes the noise, can also be an indication of worn bearings.
Old Nov 4, 2006 | 07:36 PM
see5's Avatar
see5
Don't panic yet, there is a lot more noise under there with headers.
Old Nov 6, 2006 | 07:26 AM
BBQ's Avatar
BBQ
I don't have headers!
Old Nov 6, 2006 | 07:33 AM
AU N EGL's Avatar
AU N EGL
possible vacuum leak sounds like that too. Check the O2 sensors to make sure they are tight as well.
Old Nov 6, 2006 | 07:46 AM
see5's Avatar
see5
Oh, well if you did--sorry
Old Nov 6, 2006 | 09:04 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Could be piston slap. Does it happen only when the engine is cold?
Old Nov 6, 2006 | 10:19 AM
tjwong's Avatar
tjwong
How loud is the noise? One time we had a customer thinking it was a engine knock and I even thought it was. It turned out to be the internals of the CAT that came apart and was knocking with every exhaust pulse. It sounded just like a bearing knock!
Old Nov 6, 2006 | 05:01 PM
BBQ's Avatar
BBQ
its not just when its cold. I guess first thing is to get the car on a lift. So far I have just had it up on jacks. I was flat on my back with a flashlight.
Old Nov 6, 2006 | 05:14 PM
vettenuts's Avatar
vettenuts
If you can record the sound it might help.
To catastrophic engine problem?
