After setting Two weeks battery is down
Old Nov 12, 2006 | 11:14 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default After setting Two weeks battery is down
It done this a while back so i thought the battery was bad so I got a new one and it still does it. Is it because of all the electronics on these cars? Will it hurt to just unhook it when I have it setting for a while?
Old Nov 13, 2006 | 02:48 AM
jmliles's Avatar
jmliles
It's best to unhook the battery if it's going to sit for an extended period of time. You also might want to look into a battery tender if you're going to leave it sitting often.
There are lots of little things that can drain a battery over a week or two... even a key fob in left in passive mode within range of the car can drain it eventually if the DIC is set to respond to it.
Old Nov 13, 2006 | 05:00 AM
briann510's Avatar
briann510
My car can sit for a couple months (last winter it sat for almost 3) and fire right up. I dont understand some of these cars that need battery tenders on them if they sit even a couple weeks.
Old Nov 13, 2006 | 06:05 AM
vettenuts's Avatar
vettenuts
I keep the battery tender on mine as well. Our BMW does the same thing, I think the alarm also draws more if the car is locked so I don't lock the Vette in the garage. Not sure what I would do if I ever left the BMW at an airport for two weeks
Old Nov 13, 2006 | 07:08 AM
AU N EGL's Avatar
AU N EGL
Battery tender is a good option
Old Nov 13, 2006 | 07:24 AM
mvvette97's Avatar
mvvette97
thanks guys, I may check in to a tender.
Old Nov 13, 2006 | 10:29 AM
R Devil's Avatar
R Devil
Old Nov 13, 2006 | 10:40 AM
mvvette97's Avatar
mvvette97
Originally Posted by R Devil
Hey R Devil, where is Blue Grass iowa?
Old Nov 13, 2006 | 10:49 AM
R Devil's Avatar
R Devil
10 miles east of Davenport on hwy 61
Old Nov 13, 2006 | 11:07 AM
tiojames's Avatar
tiojames
I got a friend of mine to put a disconnect on his BMW. He travels often and had to call AAA a couple of times. Mounts right on the battery and you just flip the handle. Downside is no alarm.
Old Nov 13, 2006 | 02:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to do a current draw test to see how much current you car is using once it goes in to the SLEEP MODE. There are many things that can cause excessive curent draw. Your car should draw right around 20-25 milliamps once the BCM goes to sleep.
BC
Old Nov 13, 2006 | 06:27 PM
bighank's Avatar
bighank
Default Iowa
I used to live in Bettendorf, Iowa
What do you use to warm up the car parked outside in -20 degree COLD? My old chevy pumped 5 quarts of oil on the street after sitting there following a blizard. BIGHANK
Old Nov 13, 2006 | 09:33 PM
mvvette97's Avatar
mvvette97
That's easy, I just don't drive it when it's that cold.
Old Nov 13, 2006 | 10:15 PM
SLPRC5's Avatar
SLPRC5
Yup Marc that's the ticket..get a tender for the batt.
To After setting Two weeks battery is down
