Removing Seats
Nov 13, 2006 | 01:31 PM
Removing Seats
Hi all, is there any info. and pictures showing the removal of seats from a 98c5? I want to shampoo carpet.
Nov 13, 2006 | 02:06 PM
4 bolts on each corner, one plug for power controls. Yank out. Its a 15mm socket/wrench for the bolt.
Its harder to change the oil than removing the seats
Nov 13, 2006 | 02:08 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its very simple. The only precaution that you need to take will be to make sure that the seat tracks dont scrape any interior stuff. They will leave a NASTY gouge. If it is your first time, get some one to help you guide the seat out from the oposite side.
BC
Nov 13, 2006 | 02:09 PM
Quote:
Keith
Nov 13, 2006 | 07:01 PM
Here's some photos for you.
http://www.vetteessentials.com/instr...er_change.html
For me it was easier to remove the plug on the seat and then disconnect. Simply compress the pin with a pair of pliars and push through the hole.
Nov 14, 2006 | 03:39 AM
the Vette Essentials instructions are great.
The plug was a PITA to disconnect but the rest is plain sailing.
Nov 14, 2006 | 07:38 AM
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
And some more pics...........pulled ours for seat cover install
http://temp.corvetteforum.net/c5/30s..._Coupe__.shtml
