Mechanical Engineering Student needs some help... LS1 Specs
Old Nov 18, 2006 | 10:27 PM
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
Default Mechanical Engineering Student needs some help... LS1 Specs
Hey-
I'm a ME student at SDSU and am working on a design project. My group has to "reverse engineer" an crankshaft from an car and do a lifetime fatigue analysis on it. Most of the project is failry straightforward... but I do need some information that is beyond what is usually published online or in magazines.
I was hoping that someone here would have the info we need, or could direct me to somewhere that may have it.
Thanks in advance.
Old Nov 18, 2006 | 10:58 PM
BlackZ06's Avatar
BlackZ06
Depends on what you're looking for in the way of crankshaft data. The service manuals list things such as the main journal diameter. It also lists acceptable limits such as the main journal diameter service limit (the smallest diameter it can be).
Obviously these are dimensions a mechanic would be checking when servicing the crank. It doesn't list things like the weight of the crankshaft or external dimensions since those aren't something that would concern a mechanic.
Maybe you could give us a better idea of what you're looking for ??
HTH
Old Nov 19, 2006 | 12:04 AM
Illini82's Avatar
Illini82
St. Jude Donor '07
Like said above, it depends on what you're looking for and what the goal of the project is. Either way, I don't see any way around probably having to measure something to get some dimensions. You're NEVER going to find engineering drawings for any production cranks. If you really need to be accurate, you're going to have to find out where the bearing lube holes are drilled as well as many other things.
Just another suggestiong, unless the project says you HAVE to do a V8, why not do a 4 cylinder? Without clearly thinking about the problem, it would seem like it may make thing a little more simple?
Good luck!
Old Nov 19, 2006 | 05:53 PM
cebars's Avatar
cebars
Lots of info re weights, etc. at:
http://forums.corvetteforum.com/showthread.php?t=984927
but could not find crankshaft weight there but did not go to references given.
You might try a search that would include the archives.
Old Nov 19, 2006 | 07:36 PM
vettenuts's Avatar
vettenuts
What type of information? I would think you would be looking for things not in the manual, like fillet diameters and cross sections so you can establish the stress fields. Might see if a sponsor in your area has one they have in the trash that could be used.
Old Nov 19, 2006 | 08:16 PM
cruisemon's Avatar
cruisemon
You will not only need bearing journal diameter, you need to know the alloy that was used to make the crank, how it was heat treated and more. Your professor has sandbagged you. Reverse engineering an engine crankshaft, whether 4, 6, or 8 cylinder, is going to keep you busy for a LONG time just getting dimensional and metallurgical specs on the piece. When you finall get all that info, THEN you can begin reverse engineering it.
Charlie
Old Nov 19, 2006 | 10:36 PM
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
Charlie
Yes.. he did sandbag us.
We can make some "reasonable asumptions" about what the crankshaft is made out of. The project is more to apply specific analytical techniques to an already proven design.
So.. what I need:
Crankshaft overall length
Main journal Diameter and length
Rod journal length and diameter
crank through...
if anyone happens to know the cylinder pressure devloped during a power stroke, that would be extra sweet as well.
thanks!
Old Nov 20, 2006 | 08:57 AM
steveC5's Avatar
steveC5
Originally Posted by ELTGuy_C5
Hey-
Thanks in advance.
You could always go for the extra credit and have your group chip in and buy one and make the measurements yourself!
$200
http://cgi.ebay.com/ebaymotors/2003-...spagenameZWD1V
Old Nov 20, 2006 | 10:19 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
So.. what I need:
crank through...
thanks!
Direct from a new LS7
Max cylinder pressure = 1880 PSI
Old Nov 20, 2006 | 10:42 AM
BlackZ06's Avatar
BlackZ06
For the LS1 engine:
Main Journal Diameter ---- > 2.558 - 2.559 inches (64.993 - 65.007 mm) Minimum size (service limit) 2.558 inches
Con rod journal Diameter ---- > 2.0991 - 2.0999 inches (53.318 - 53.338 mm) Minimum size (service limit) 2.0987 inches (53.308 mm)
Service Manual does not list other dimensions.
Old Nov 20, 2006 | 12:28 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
You can calculate cylinder pressures easily using simple thermo equations.... you know power, cylinder volume, CR. Can find the max temp using the power. I'd imagine you're prof is expecting you to show how you found the pressure, and I doubt he'd accept "CorvetteForum" (even though I've never got bad info here)
Old Nov 20, 2006 | 03:15 PM
cruisemon's Avatar
cruisemon
And if this professor dude is anything like the ones I had when I was an engineering student, take great care to make all your calculations at standard conditions and to specify clearly what they were. When you get to the part of the process that begins to look at the effect of ignition timing advance on peak cylinder pressure, you need to either lay in a supply of Xanax or Jack Daniel's or maybe both. I would be stunned if there isn't a computer program lurking in the weeds somewhere that will calculate these very parameters. Once you get a grip on those parameters and start dialing in cam lobe separation angles, valve open/close timing, etc., you'll really appreciate better living through chemistry.
Is there any chance there is anyone reading this board that is in engineering with an auto maker? I had a buddy at Chevrolet engineering but he has retired (he's the one that worked on development of the LS7 and told me the engine could make 700 hp normally aspirated - couldn't drive it on the street or get it to idle below about 1200 rpm, and the cam didn't clean up until about 3000 rpm but it makes a LOT of horsepower above 6000 rpm and had practically a flat torque curve from just over 3000 rpm up to about). 6000)
Charlie
Old Nov 20, 2006 | 06:13 PM
Patches's Avatar
Patches
Here's a table from my website detailing the engine mechanical specs for a 2002 LS1. This is directly out of the service manual.
LS1 Engine Mechanical Specs
Old Nov 20, 2006 | 09:18 PM
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
Thanks for all the replies. I've got most of the data I need now. I spoke with the prof and we're to assume Ideal Gas Isentropic behavior for cylinder pressure.
All I need now is main and rod bearing cap widths and I should be good to go!
Old Nov 20, 2006 | 09:43 PM
cruisemon's Avatar
cruisemon
Isentropic and ideal gas and optimum ignition timing simplify things a bunch
Charlie
Old Nov 20, 2006 | 09:54 PM
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
Charlie
Yes it does. The point of the project isn't to simulate an engine, but to apply the theories of internal & surface fatigue analysis and bearing design to real world problems.
Out of all the classes I've taken so far, this and my CAD classes have been the most informative.
Old Nov 21, 2006 | 12:19 AM
Illini82's Avatar
Illini82
St. Jude Donor '07
I just finished grad school this summer and felt like I had forgot everything I learned in the 5 yrs I was in school, but you'll be suprised how much you actually remember when you need to. Just remembering the basics will be enough to get you by, and then when you need to dig deeper you'll find yourself saying "oh yea" a whole bunch when you look things up
Old Nov 21, 2006 | 02:30 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Im working on a similar project and we have to do bolts that secure a gimbal to a floater deck. BS i want to study camshafts Looks like you got your info good, wishi could be of some help
Old Nov 21, 2006 | 07:53 PM
Sawbladz's Avatar
Sawbladz
You have no idea how much that terrifies me. Im in my second year Automotive Engineering at UOIT in Canada, and I keep thinking that I will never remember all tis stuff once Im out in the real world. Thanks for making me feel like Im not the only one.
To Mechanical Engineering Student needs some help... LS1 Specs
