C5 Overheat Problems???
Old Sep 23, 2001 | 02:45 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default C5 Overheat Problems???
Coming back from the Nopi event in Atlanta the last weekend made me wonder if my car has overheat problems. The reason I have not noticed is b/c I have not sat in stop n go traffic for an hour or longer.
Outside temp was about 80 degrees. Sitting in traffic after about 20 or 30 minutes I noticed my temp was around 230 degrees. When I could get up to 30+ mph the temp would go down to about 210 or less. Is this normal? My car is stock minus exhaust and filter.
It seems like more of a fan problem than a lower degree thermostat b/c once I was moving my temp went down.
Any help???
Old Sep 23, 2001 | 10:06 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: C5 Overheat Problems??? (C5-VERT)
unless I've got the same problem, it sounds normal
Old Sep 23, 2001 | 01:35 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
This is a normal condition for your car. :yesnod:
vetterdstr :cheers:
Old Sep 23, 2001 | 01:42 PM
Viprklr's Avatar
Viprklr
Default Re: C5 Overheat Problems??? (vetterdstr)
I significantly lowered my temps. by going with a tstat/fan control combo from Nate at Xtreme. The fan kicks on at 172. My coolant temps rarely go over 185 in normal driving and in stop and go/hard driving usually no more than 199. Hope this helps. :yesnod:
Old Sep 23, 2001 | 02:59 PM
Evil-Twin's Avatar
Evil-Twin
If you notice the red line on the temp is above 230 F . if your stuck in traffic bumper to bumper.. there is very little cooling from your air intake, which is about 6 in off the ground... even with 80 temps.. the road surface gets up to 120 F.. I lazer tested road temps at 95 F... black top can get to 160 degrees.. cement surface 140 F. There is very little cooling from temps like this.. a fan controller will help.. a lower thermostat will help but it will not help by itself..
Old Sep 23, 2001 | 03:09 PM
Mystery Fan's Avatar
Mystery Fan
You might want to check to see if you have some trash that has blown up in between the shroud and the radiator. When I changed to a ram air setup, I had to change the shroud. I found a bunch of trash at the top of the radiator. Enough for a bird to have a nest.
Old Sep 23, 2001 | 05:25 PM
sandbagger's Avatar
sandbagger
Default Re: C5 Overheat Problems??? (Mystery Fan)
Ditto on the junk accumilated on the radiator!
This is something everyone should look at.
The temps are normal though!
:flag
Old Sep 23, 2001 | 06:39 PM
CCS's Avatar
CCS
Default Re: C5 Overheat Problems??? (sandbagger)
If your in traffic ...turn on your A/C and it will kick the fans on and keep your Coolant Temps. around 210..... I see temps of 172 on the freeway and 180 in traffic with my mods...
Old Sep 23, 2001 | 08:42 PM
C5-VERT's Avatar
C5-VERT
Default Re: C5 Overheat Problems??? (CLAYSREDVERT)
Thanks guys, I did notice with the AC on the temp would drop. But it's kind of an oxymoron with the top down and AC on...
Oh well, I guess it didn't hurt to think I was overheating. Alteast that kept me from the temptation of racing all of those rice-burners on the way home from the NOPI event. ;)
[Modified by C5-VERT, 12:43 AM 9/24/2001]
Old Sep 23, 2001 | 09:03 PM
LoneStarFRC's Avatar
LoneStarFRC
Ditto what Viprklr said. The unit does a good job of keeping temps lower. One drawback that I see though is that it increases the duty cycle of the fans and therefore will probably shorten their lifespan somewhat. Also, I haven't had this mod installed over the winter months yet. I'll be keeping a close eye on this. Don't want too much of a good thing!
Old Sep 23, 2001 | 09:17 PM
Da Kind's Avatar
Da Kind
Default Re: C5 Overheat Problems??? (Tx99FRC)
230 is normal. Don't worry.
Old Sep 24, 2001 | 01:53 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: C5 Overheat Problems??? (Da Kind)
Ditto, Its Normal. Don't worry about it. Its not a 1955 car.
Bill
Old Sep 24, 2001 | 03:28 AM
hrdtopv8's Avatar
hrdtopv8
Hey C5-Vert,
Did you see my vette at the show? I had the Pewter hardtop with the BPP hood and nitrous setup.... I didn't see yours unless you didn't enter... What did you think of the show? :chevy :seeya
Old Sep 27, 2001 | 10:48 PM
C5-VERT's Avatar
C5-VERT
Default Re: C5 Overheat Problems??? (hrdtopv8)
Sure did! I think you may have walked off when I saw it. I was with my friends 300zx TT, which was right across from you. Definately liked your setup!
Actually I parked outside. I didn't even think about entering my car in there until it was too late. I honestly thought it was more of a foreign car event. Go figure...
To C5 Overheat Problems???
