Noticed balancer has a slight wobble
Old Nov 30, 2006 | 05:26 PM
bubs99's Avatar
bubs99
Default Noticed balancer has a slight wobble
Changed lower belt (a/c) and never noticed before and after installing belt and looking for any problems noticed the harmonic balancer has a slight wobble. Is this a concern, normal, or what ????
Any help.
Old Nov 30, 2006 | 05:35 PM
jmiller's Avatar
jmiller
I'm having the same issue. Apparently they all wobble slightly. If it wobbles too much it can come off and cause major problems. The question is how much is too much. I'm going to video mine, and see if I can get any expert advice.
Old Nov 30, 2006 | 05:41 PM
bubs99's Avatar
bubs99
Default Wobble
Thanks for replying, let me know what you fiind out. Anyone else have this issue??
Old Nov 30, 2006 | 06:10 PM
vettenuts's Avatar
vettenuts
Seeing the age of the car, I wouldn't wait. Either fix it or get it fixed, because if it comes off it can do quite a bit of damage not to mention that is probably not now performing its primary function, which is damping out the crankshaft harmonics.
Old Nov 30, 2006 | 06:52 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
I agree 100%. If it is wobbling, I would change it out before it gets worse. This is a good time to either go with a new cam or put on an underdrive pulley.
To Noticed balancer has a slight wobble
