Tire sensor upgrade
Old Dec 1, 2006 | 10:06 PM
jrprich's Avatar
jrprich
Default Tire sensor upgrade
Anyone know what it takes to upgrade a 99 to use 01-04 Tire Pressure Sensors ? What has to be swapped out or reprogrammed ?
Old Dec 2, 2006 | 01:40 AM
zozmanZ06's Avatar
zozmanZ06
Default Incompatible
The 97-2000 and 2001-2004 use non-compatible tire pressure sensors which operate on the door locking component of the BCM. There are no upgrades for a 97 to the 2001-04 sensors. You can re-program them for the applicable car year and sensor.
Randy
Old Dec 2, 2006 | 09:39 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It will not work! NO WAY, NO HOW, NO GO! DO NOT waste your money trying!
Old Dec 5, 2006 | 11:59 AM
bighank's Avatar
bighank
Default tire sensors
The tire sensors AND the keyless entry fobs both transmit to a receiver that takes both signals and sends appropriate codes to the BCM.
If you wanted to change the receiver (Why the h*** would you) you would have to get new key fobs and reprogram the BCM. Might be possible but not very practicle. 97-00 use one frequency and 00 and later another.
BIGHANK
To Tire sensor upgrade
