Check Engine Light
Old Dec 3, 2006 | 04:27 PM
nlreb54's Avatar
nlreb54
Default Check Engine Light
Which O2 sensors will trip a P0133 or P0153 code? I have both codes and a CEL also. Can I continue to drive the car until I can replace them? Long tube headers and high flow cats installed also.
Old Dec 3, 2006 | 04:45 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0153 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
These codes indicate you have an issue with both front O2 sensors..
With long-tube headers it is a common requirement to swap out the original front O2's with the part numbers used in the rear (the rears are more sensitive / have a different heater element).
Don't assume the front O2's are "defective" (i.e. spending money on new front sensors is not your best move); more likely they won't work at all in your application.
Old Dec 3, 2006 | 06:15 PM
nlreb54's Avatar
nlreb54
Will swapping the front sensors with rear ones need any special tuning?
Old Dec 4, 2006 | 03:20 PM
dougbfresh's Avatar
dougbfresh
I "think" he's saying you'll need to use NEW rear O2 sensors in the front, leaving the old rear ones in place.
Old Dec 4, 2006 | 07:20 PM
Dan_the_C5_Man
If you have rear O2's in operation (i.e. not deleted).
No tuning necessary that I am aware of on a rear to front swap.
Old Dec 4, 2006 | 08:40 PM
Bob Chapman's Avatar
Bob Chapman
You can keep driving - it's an emission issue. If you use rear O2s in the front you need adapter harnesses - call Bobby at LG Motorsports - they have them.
To Check Engine Light
