Wideband sensor
Old Dec 6, 2006 | 02:15 PM
Dirty Howie's Avatar
Dirty Howie
Originally Posted by Billdog350
Some O2's are double duty. I can calibrate my LC-1 auxiliary output to match a narrowband (0 to 1 volt) signal to the PCM. You can change the drop off rate and sensitivity so it looks exactly like a narrowband to the ECU.
So if I understand you correctly......
You have a wideband sensor in one of the existing sensor positions. Then you calibrate that sensor to act as a narrow band during normal use and a wideband during tuning ????
And if this is correct....do you have it in front or back. Seems that even when you are tuning you need the front sensor providing normal narrow band feed back to the PCM.
DH
Old Dec 6, 2006 | 02:21 PM
Billdog350's Avatar
Billdog350
DH
Howie, the LC-1 has 2 analog outputs as well as a digital output cable! If you're using it as a narrowband, you're right that it should be used in the upstream (front) location. The LC-1 would we wired up with a "on" when the ignition is on, the cable for the serial connection to your pc would be run to somewhere inside your car, along with one of the analog outputs for a wideband meter. The other analog output would run to your narrowband connector to feed the PCM. Here is the missing step I haven't mentioned. You need to log onto your LC-1 with your laptop and "flash" or "set" it with the included LC-1 program so that you can tell it what analog 1 and analog 2 are supposed to do. There are options for oem narrowband, wideband meter, etc. you can even set the calibration for methanol, propane, gasonline, etc since lambda/AFR will be different for each fuel source.
Old Dec 6, 2006 | 02:56 PM
Dirty Howie
Originally Posted by see5
Speedy,
You are fully bunged up!
I used the Ebay bung as well, but only a lowly, single.
I'd say he's a proctologist
DH
Old Dec 6, 2006 | 03:43 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Optimum location for any W/B sensor is before the cat converters, in a location similar to Mike Mercury's post.
Most tuners claim approximately 2 tenths (lean) difference between before and after the cats.
Old Dec 6, 2006 | 06:20 PM
Mike Mercury's Avatar
Mike Mercury
Using rear bung or tailpipe is not more than a few tenths difference.
but it's not a constant; and that's where the problem is. The amount of variance depends on the efficiency of the cat.
May not be a problem if you have the effeciency rating of that cars particular converter.
But then it becomes a problem because the efficiency of a catalytic converter changes over time. So, to do an accurate variance calculation of the amount a converter alters an AFR reading - would be calculated by:
a). The efficiency of that particular cat.
b) then further skewed by the mileage of the car.
Does such data exist ????
Who drops their car off at a tuner, pays $350 to $600, and then says "do your best guessing" ???
Cats do not remove O2.
I thought you said "not more than a few tenths difference".
This is exactly what I said and people jumped all over me.
no one "jumped" all over you... you said "supposedly before cat, after cat, and tailpipe will all read similarly"; and that needed to be corrected.
Furthermore there are TONS of legit tuner shops who shove a sensor in your tailpipe regardless if you have cats.
OK then; name just 5 , so we can determine for ourselves whether they are "legit" or not.
Old Dec 6, 2006 | 06:52 PM
see5's Avatar
see5
Mike,
The repeatability of a 02 sensor is not 100%, narrow or wideband, let alone between two different sensors. I have dynoed many times with no cats my PLX in the header and dyno shops Bosch (same) in one tailpipe. Do they read together- no. Close, but about the same as with cats. Do cats degrade, sure but it does not seem to bear on the 02 content.
I have only used 3 different dynos and they all use tailpipe sensors by default. What is a tuner to do, there are not many folks around with welded precat bungs.
Most of us who self tune have bungs welded in because we are relatively hard core, but I have no qualms about using after cat bungs because it proves out every time. Maybe a tenth or two but that is within normal variance.
Just my experience---
Old Dec 6, 2006 | 08:56 PM
Billdog350's Avatar
Billdog350
I said similarly, not "exactly the same"...whatever, we're getting into symantecs now.
Regardless, in a N/A application you're not going to melt down your motor with a few tenths difference. If you're not getting knock and you're at 12.8:1..even if its really 13:1 you're ok....Most NA LS1's that I've seen don't care a few tenths either way for hp...I mean 12.6 vs 12.9 and you're within 2-5hp....that's not much of a difference. If you're looking for the "optimal" location of the sensor, closer to the collector will be your best bet on a header car....but anywhere in the exhaust system will get you in a safe tune that puts out good hp.
My "street" tune on my LC-1 was dead nuts matching the sensor at the dyno when I tested it a few days later.
Old Dec 6, 2006 | 09:13 PM
muncie21's Avatar
muncie21
2 comments:
1) Most wideband systems have a method for simulating the narrow band signal. Therefore you can run a WB in place of an existing NB sensor. Downside to this is if, you have issues with the WB, most likely you'll have NB issues also, which will affect how the car runs in CL mode.
2) Most (every??) dyno's use WB sensors in the tail pipe. These units are not calibrated to each individual 'cat' efficiency. Therefore I'd would suggest that the difference in O2 readings is not significant between pre and post cat readings.
