Missfire at idle
Old Dec 6, 2006 | 01:02 PM
cbtimko's Avatar
cbtimko
Default Missfire at idle
My 98 started to missfire 2 days ago, it's a daily driver. It is not throwing any codes on the DIC. I had another 98 that had a similar missfire due to a bad plug wire found by a scan at the dealership. A friend told me Autozone would scan it for free, but the Autozone employee said the check engine light would have to be on and it is not. Not sure if I should spend $100 for the dealer to scan it or spend that $ on new plugs/wires. Is there anything else that would cause an occasional miss? I've been told the coils rarely go bad. Trying not to spend any more than I need to with Xmas just around the corner.
Thanks in advance for any help
Old Dec 6, 2006 | 01:36 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
First item to suspect would be spark plug wires, next plugs (especially if they have a lot of miles on them). Wires can look "o.k." from the outside but damaged on the inside. And if they are the original wires, more than likely they will not survive the removal / re-installation process. So you should plan on buying new wires before you begin checking the park plugs.
Old Dec 6, 2006 | 01:48 PM
cbtimko's Avatar
cbtimko
Thanks Dan, any recommendations on plugs/wires? The car has 50,000 miles, I've had it for the last 10,000. I'm guessing the OE stuff is still there. LG street headers are in the plans, do I need a certain wire for that or will "cool socks" do the job? Is NGK's tr55 still a good way to go?
Old Dec 6, 2006 | 03:29 PM
Dan_the_C5_Man
TR 55 on the plugs, Magnecore makes a good wire set, some folks like MSD's, some don't. I have MSD's on mine, no issues, but when I swap them I'll go with Magnecore.
If you have the stock plugs, no doubt the platinum pucks have fallen off, dramatically increasing the gap.
If it were me, I would go ahead and swap both plugs and wires.
Old Dec 6, 2006 | 03:42 PM
jbauch357's Avatar
jbauch357
You say that it does this at idle, and not any other RPM correct?
Just wondering cause both my 97 Formula Firebird and my Z06 have a slight stumble at idle but seem to run fine otherwise. I was told this was common on GM small block EFI motors...
Old Dec 6, 2006 | 03:58 PM
Dan_the_C5_Man
That is certianly true; my LS1 idles like sh*t but runs very, very strong. I didn't mention this becuase the post stated "started to misfire 2 days ago.."
Old Dec 6, 2006 | 04:00 PM
cbtimko's Avatar
cbtimko
Correct - only at idle
Thanks Dan, I apprecaite the help
To Missfire at idle
