Car Backfiring/sputtering After Lt Install
Old Dec 12, 2006 | 05:15 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Originally Posted by blackc598
so i found out my code PO340. catalyst system efficiency below threshold (bank 2)... is this the right rear 02 sensor??
Check out the code again. 340 does not compute (cam shaft position sensor). If this is indeed the code, you are on a new diagnosis track.
Old Dec 12, 2006 | 05:28 PM
blackc598's Avatar
blackc598
Ok My Bad .. Wrong Code PO430 I believe is the correct one.... But if It Is The Bank 2 Problem ... Which 02 Sensor Is That??
Old Dec 12, 2006 | 05:31 PM
Dan_the_C5_Man
Bank 2 is the passenger side, it would be helpful to post the correct code, will tell us if it's front or rear. As previously stated, rear O2's won't cause the issues you are having.
Old Dec 12, 2006 | 05:37 PM
blackc598's Avatar
blackc598
i believe the 02's will because when the codes cleared the car runs like a champ. when the code comes on the motor is running way rich. im changing my plugs, but i dont think thats the problem. i know its my 02's becuase before the swap the car ran perfect.
Old Dec 12, 2006 | 06:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On some C5's, unless the cylinder misfire is severe or happening over a long period of time, it wont set a DTC code. It will however, cause the check engine light to "FLASH" while the event is happening. Some advanced tuning software will tell you the exact cylinder expierencing the problem. If it does set the misfire DTC, it will be a P 0300 code.
BC
Old Dec 12, 2006 | 06:27 PM
blackc598's Avatar
blackc598
my engine light comes on and stays on so i dont think that could be the problem... im just gunna go with the 02 sensor and shoot from there. i appreciate all the help!!
Old Dec 12, 2006 | 11:23 PM
Dan_the_C5_Man
P0430 - Catalyst System Low Efficiency Bank 2
This is the right-hand side (passenger) rear (after cat) O2 sensor.. BUT, that doesn't mean it's "defective", and replacing it will not necessarily solve your issue. This is not to say that you don't have an issue with a front O2, or a spark plug, or plug wires, etc.
Old Dec 13, 2006 | 12:03 AM
blackc598's Avatar
blackc598
im not replacing it.. im going to my tuner saturday to have him delete the 02's in the rear. my plug wires are new and so the only thing im going to replace are my spark plugs. with ngk tr55gp's.
Old Dec 13, 2006 | 04:18 PM
blackc598's Avatar
blackc598
would a clogged cat cause these problems??
Old Dec 13, 2006 | 11:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Y yes it can!
BC
Old Dec 13, 2006 | 11:25 PM
blackc598's Avatar
blackc598
well i found out my problem... the stock plugs are gapped to far. i installed some ngktr55's at .050 gap and they work perfectly. im having no more misfiring or sputtering at WOT. thanx for the help guys
Old Dec 14, 2006 | 01:40 AM
Dan_the_C5_Man
Excellent result! That must have been quite a gap! If they are the original GM plugs, the platinum pucks probably fell off, which is why the gap was excessive. For the record, most of us do not re-gap the NGK's; as long as they all look the same (no one dropped them in the box, etc.), they are plug and play.
