Help With Abs Message!
Old Dec 15, 2006 | 10:02 PM
allmee's Avatar
allmee
Default Help With Abs Message!
On my way home from work tonight, I was getting a little heavy with the foot in 1st & 2nd and I started getting 2 messages flashing on my display: "Service Active Hndlng" & "Service Traction Control", and my ABS light came on and stayed on. I always switch of my traction control, so the system was not doing any work in that area. After shutting down and pulling the key, when I restarted the car, all seemed fine.
Does anyone have any info on what this may be and if it could be something simple I could check?
Thanks!
Rob
Old Dec 15, 2006 | 10:08 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Most of the time it's a loose / poor connection on one of the wheel sensor cables.. Check you DIC, see what it says. (display the codes; hold "Options" down, press "Fuel" 4 times in a row, post the codes in this thread).
Old Dec 15, 2006 | 11:01 PM
allmee's Avatar
allmee
Those codes fly pretty fast! I think I got em
28TCS C1242 H
60IPC B0521 H
BO RFA U1064 H & U1000 H
A1-RDCM 2285 H & U1064 H
A0-LCDM U1064 H
A0-RCDM U1064 & U2285
Is there a way to freeze these codes for easy writing?
I think I got em all! I really appreciate the help!!
Old Dec 15, 2006 | 11:31 PM
Dan_the_C5_Man
28TCS C1242 H
60IPC B0521 H
A0-LCDM U1064 H
C1242 is the one you are concerned with, it is responsible for lighting up the service TCS and ABS indicators.
This code is set when a poor ground is detected within the ABS pump circuitry. At this point it looks like you may have an intermittent continuity issue within circuit #1250.
The "H" after the code indicates "history", i.e. this condition is not currently present.
Check out ground points G101 and G108.
Check out Bill C.'s tech tips and threads regarding poor grounds, where they are and how to clean them.
P.S. the IPC code B0521 indicates you are spinning the motor over 7400 RPM's; knock it off!
Clear all the codes currently displayed, check those grounds, drive it and see what else (if anything) pops up. It's good practice to run the check codes routine every once in a while.
Old Dec 16, 2006 | 12:02 AM
allmee's Avatar
allmee
Thanks soooo much!!! That 7400 MPR code must be from a previous owner! I am the 3rd! I NEVER go over 58-5900 RPMs, she's my baby and I do no abuse her at all!! I am one of the crazies that does my oil change between 2000 & 2500 miles!
Thanks again Dan!!
Rob
Old Dec 16, 2006 | 12:05 AM
Dan_the_C5_Man
Thanks again Dan!!
Rob
No problem.. If you (or anyone else) had actually turned the motor that many RPM's, you'd have a "vented" block where the rod poked a hole in the side. You have a rev limiter to prevent this. This is another "intermittent" issue, this time with the tachometer.
Don't sweat it unless it keeps coming back.
Old Dec 16, 2006 | 12:20 AM
allmee's Avatar
allmee
My coupe is an '01 that I purchased in Sep of '04 with 10300 miles. G-- only knows what the 2 previous owners may have done with my baby. I have never checked the codes before and I imagine some are rather old. Is there a special way to clear the codes?
Thanks!
Rob
Old Dec 16, 2006 | 12:23 AM
Dan_the_C5_Man
Thanks!
Rob
From our very own "tech tips" section. https://www.corvetteforum.com/techti...D=25&TopicID=1
Old Dec 16, 2006 | 12:25 AM
allmee's Avatar
allmee
One other thing....on Bill's diagram of grounding points, I don't see a 108. I see the 101 but not the other. ? Did you mean another #?
Old Dec 16, 2006 | 01:28 AM
ZeeOSix's Avatar
ZeeOSix
After the codes are automatically cycled through, it will go into the "Manual Diagnostics" mode. Use the "Options" and "Trip" buttons to scroll manually through the DTCs. That way you don't have to try to capture them as it automatically scrolls through them.
Old Dec 16, 2006 | 01:30 AM
allmee's Avatar
allmee
Thanks! I had a tough time trying to catch those babys!
I appreciate the info!
Rob
Old Dec 16, 2006 | 01:46 AM
Bill Dearborn's Avatar
Bill Dearborn
As mentioned above you could have a ground problem but you may not have any problem at all. Sometimes this just happens due to an unexpected variation in the signals received at the EBCM. This syndrome never seems to happen while people are braking just when they are on the throttle. It happens often enough that one C5 racer has installed toggle switches on his 99 FRCs so the driver can power the EBCM off and on while running in a race thus resetting the ABS. Usually the failure occurs when the car runs over a rough patch of pavement or something similar.
Bill
Old Dec 16, 2006 | 03:22 PM
DansVette's Avatar
DansVette
I've got the same problem, and when I try the above procedure nothing at all happens, the display doesn't show any codes. Help ?
Old Dec 16, 2006 | 05:59 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ground G-104 is also called G-104/108 on the later C5. Its the metal ground stud on the frame next to the inboard side of the battery.
BC
Old Dec 16, 2006 | 10:01 PM
allmee's Avatar
allmee
BC
Got it! Thanks!!
Old Dec 17, 2006 | 03:00 AM
QuickSilverLS1C5's Avatar
QuickSilverLS1C5
I have the same issuue with my C5, the ABS lights and TCS lights pop up. Only when I hit bumps or uneven paved roads. How do the wheel/abs sensors look like, I want to take them off and clean them see if the fixes the problem. Thanks!
Old Jan 22, 2007 | 08:46 AM
vetdude's Avatar
vetdude
Got the same two messages yesterday morning ("Service Active Handlng" & "Service ABS") on the DIC, as well as the lights on the gauge cluster that are staying on. I had just installed a new battery prior to this. Never had the messages before installing the battery so could they be related? How/should can I get rid of them or should I take it in for service?
Old Jan 22, 2007 | 07:07 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please read and post your DTC codes. Once you have them written down and posted, CLEAR THEM>
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Sound effects are cool too! 
BC
Old Jan 22, 2007 | 09:02 PM
biglu187's Avatar
biglu187
I had a simular issue recently and found it to be a bad fuse. Here is the post I had and these guys fixed me right up. Hope it helps.
http://forums.corvetteforum.com/show....php?t=1604202
To Help With Abs Message!
