why do cammed LS1s always tick?
Old Dec 20, 2006 | 08:38 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Originally Posted by vettenuts
Its not the springs. I have run both duals and now PSI beehives, no noise from either. What is the lobe of your Comp Cam?
Mine is just the XE lobe, not the XER. I bought a Comp pushrod checker and from what I could tell I needed the 7.4 pushrods. There is a guy on LS1tech that has my exact came cam i have and he runs the 7.425 so I guess I don't know.
Old Dec 20, 2006 | 09:20 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Originally Posted by Y2Kvert4me
G5X4 cam (24x/24x XE-R lobes on a 111 lsa), PRC dual springs, 7.425" pushrods.
Stock heads, lifters, rockers, etc. (for a limited time ).
Engine is very quiet, no ticking. Inside the car with radio off, if you focus really hard, you can detect a faint "sewing machine" sound...but it certainly isn't obvious or noticible.
I was actually surprised at how quiet it was when I first drove it after the cam swap.
Of course I can never be content, so the car is in the process of being torn down again to flycut the pistons, and put on some stage 2 TEA 5.3 heads, GMPP "caddy" lifters, ARP studs, .040" Cometics, and probably some adjustable roller rockers.
Damn Tom, that thing is going to be even more of a beast now... cant wait to here the results
Old Dec 20, 2006 | 09:49 PM
vettenuts's Avatar
vettenuts
How did you measure and what did you come up with for number of turns on the checker?
Old Dec 20, 2006 | 10:28 PM
mvvette97's Avatar
mvvette97
if I remember right I had 9.5 turns. I had a problem with the lifter wanting to pump up while I was tryin to measure it
Old Dec 21, 2006 | 07:23 AM
vettenuts's Avatar
vettenuts
You didn't happen to measure you base circle or have a way to get that number, do you?
Old Dec 21, 2006 | 11:59 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
You young Guys amuse me worrying about valve clicking noise. Obviously, you never heard an old Musclecar or early Vette with a solid lifter cam. There was no way to quiet them and the that sound was a badge of a hot engine.
Old Dec 21, 2006 | 02:03 PM
stngh8r's Avatar
stngh8r
Originally Posted by sxe60
......that sound was a badge of a hot engine.
I must have a pretty hot engine then
sewing machine checking in here too. 230/224 "reverse split" TR cam & 918 springs. I have also heard that the sound is transferred more due to alum. heads and headers?
Old Dec 21, 2006 | 02:20 PM
cam99's Avatar
cam99
Absolutely, we hear the valves closing more because we removed stock exhaust manifolds which tended to dampen out those sounds.
Old Dec 21, 2006 | 06:39 PM
bcseitz's Avatar
bcseitz
Back in the day ( oh brother here we go!), My 66 Fairlane GT had a built 390 with the most lumpy hyd. Crane cam I could find. It didn't make any lifter noise. Had a lot of noise coming from the two 4's and the exhaust though .
Old Jan 6, 2007 | 01:23 AM
mvvette97's Avatar
mvvette97
I did find out that the cam i have has a base circle raduis of .732 and the diamater is 1.463 . I was told on ls1 tech that I needed the 7.425. How did they calculate that?
Old Jan 6, 2007 | 09:40 AM
vettenuts's Avatar
vettenuts
Not sure what the stock base circle is, although I still have EG's stock cam in the other room and can measure it. But basically, your lifter now sits a little lower in the lifter bore due to the smaller base circle. The amount lower is the stock base circle diameter minus the new base circle diameter divided by two (or the stock base circle radius minus the new base circle radius). Now that you know how much lower the lifter sits, you get a pushrod that much longer and you will then obtain your original lifter preload. The stock lifters start getting noisy at less than 0.080" of preload from what I have read.
Note that injectors can be noisy, carbon in the cylinders can cause a tick and with headers any noise will be like putting it through a megaphone compared to the thick stock manifolds.
Old Jan 6, 2007 | 11:33 AM
sapper1's Avatar
sapper1
Default ticking
I had a head and cam package installed with all of the new guts as well, dual springs, rockers, pushrods, valves, dual chain timing. My builder warned me that the drivetrain would produce more noise but that it was still bullet proof, just alot stiffer moving parts to produce more power.
I have about 5k miles on the install and either my hearing is going or the noise just dosent seem as loud
Old Jan 6, 2007 | 07:37 PM
  #33
Byter's Avatar
Byter
I think it definitely has to do with the ramp characteristics of the cam lobe (most likely the closing ramp). However, nobody has said WHAT is clicking. Is it the valve closing on the valve seat? Is it the lifter coming off of the cam lobe? Is there +0 lash in the lifter/pushrod/rocker because of deflection? Something has to be MAKING the noise...
Old Jan 6, 2007 | 07:54 PM
  #34
bcseitz's Avatar
bcseitz
I wish someone had a solution.
Old Jan 6, 2007 | 08:23 PM
  #35
NemesisC5's Avatar
NemesisC5
Apparently Lunati thinks they have a solution. You have to scroll down almost to the bottom to see the LSX series cams. Anybody running these cams or know anything about how they perform?
http://www.holley.com/types/Chevy_Voodoo_Cams.asp
Scotty
Old Jan 7, 2007 | 04:56 PM
  #36
c52k1vert's Avatar
c52k1vert
916/795 rwhp C5R 412 YSI
I wonder if it is the fact that the CAM has been replaced or most everyone that replaces the CAM usually has headers installed also, which tend to be a much thinner exhaust and allow the valve train noise to be heard much clearer than stock exhaust manifolds? Just a thought.
Old Jan 7, 2007 | 11:27 PM
  #37
SLPRC5's Avatar
SLPRC5
This was mentioned in an earlier post on this thread. Also..mentioned is the injector noise...I checked mine (30#) and they send out a loud ticking sound from cycling thru.
To why do cammed LS1s always tick?
Old Jan 7, 2007 | 11:30 PM
  #38
mvvette97's Avatar
mvvette97
yes I agree with ya but like you said, they were solid lifters. A hydrolic lifter shouldn't sound like a solid lifter..
Old Jan 9, 2007 | 03:28 AM
  #39
SLPRC5's Avatar
SLPRC5
Originally Posted by bcseitz
Mine sounds like a sewing machine. And I have a baby cam, 918's with stock lifters.
I'd like to know more about these Cady racing lifters.
here is the info I got from Hammer69 on the Caddy Race lifters.
I'm ordering a set for my swap.
Some say quieter operation. With proper preload, they should last a long time. They are designed to handle 8000rpm operation and heaby spring pressures.
Also, the oil band and inlet are slightly higher on these lifters. This ensures that they get properly oiled with the smaller base circle aftermarket cams. With stock style lifters, the band has a tendency to drop too low in the bore and leak oil away from above the lifter causing two issues...lower engine oil pressure, and poor lifter oiling.
Hammer
Old Jan 9, 2007 | 09:12 AM
  #40
bcseitz's Avatar
bcseitz
Hammer
Encouraging. But I haven't heard anyone doing a retrofit with these to quiet down their valvetrain. If you do this and it works please do a post so we can all benifit. And please pm me about it as well.
I also believe the only solution to this problem is a lifter swap and lastly, only if necessary, a stronger oil pump. It's got to be because of the aggressive cam profile and extra spring pressures that the stock lifters aren't getting "pumped up" enough.
How soon are you going to try the new lifters?
Bob
