why do cammed LS1s always tick?
Old Dec 20, 2006 | 01:56 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default why do cammed LS1s always tick?
Mine and alot of others I have heard seem to tick. I used to run the longer pushrods and it still was ticky.
Old Dec 20, 2006 | 06:41 AM
see5's Avatar
see5
cam lobes
heavy springs
push rod length- length needs to be correct, not longer or shorter.
IMHO the cam lobes are the biggest factor.
Old Dec 20, 2006 | 06:52 AM
vettenuts's Avatar
vettenuts
You can quiet them some with the correct lifter preload. If you are running stock lifters, you want to be in the 0.080" - 0.100" range of preload with the stock rockers. You could just pull one rocker and make a measurement, but something like an XER lobe will be noisier.
I think Crane takes a little different approach, they go a little easier on the ramp rates of the cam and pop the valve faster using the rocker (assuming you are using the Crane rockers). It does make for a quieter setup though.
Old Dec 20, 2006 | 07:04 AM
Chevy Guy's Avatar
Chevy Guy
Depending on the design of the cam lobe you may not be able to quiet down completely. The agressive ramp of the closing of the valve lends itself to "ticking".
Old Dec 20, 2006 | 07:22 AM
Rob Petyo's Avatar
Rob Petyo
Don't have the answer but I feel better knowing now that i"m NOT the only one hearing it.
Good post
Old Dec 20, 2006 | 08:13 AM
AU N EGL's Avatar
AU N EGL
small block chevy engines almost always tick, untill properly oiled though out the engine.
Old Dec 20, 2006 | 09:36 AM
jfrc's Avatar
jfrc
for the power, looks, and handling, its something i deal with
Old Dec 20, 2006 | 10:42 AM
WKMCD's Avatar
WKMCD
My 346 w/ a 230-236 XE-R 112 cam sounded like a sewing machine. I'm running a MUCH larger cam in my 402 but use Cadillac Racing lifters and Trend .110 pushrods and it's not much noisier than stock.
Old Dec 20, 2006 | 11:47 AM
qwkz06's Avatar
qwkz06
Mine is as quiet as stock. Love it. The sewing machine sound would drive me crazy. There are some valve train improvements like identified by Vettenuts that will really help.
Old Dec 20, 2006 | 01:18 PM
mvvette97's Avatar
mvvette97
I was told that my dual springs is what is making alot of noise in mine.
Old Dec 20, 2006 | 01:20 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I've got at least a thousand miles on the new ECS cam, no tick/sewing machine sound.
Old Dec 20, 2006 | 01:21 PM
mvvette97's Avatar
mvvette97
Just wondering, you guys that say yours is quiet, are you running a single or dual spring?
Old Dec 20, 2006 | 01:41 PM
chaase's Avatar
chaase
St. Jude Donor '12
I haven't noticed any noise in mine and I believe it is dual spring.
Old Dec 20, 2006 | 01:54 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I have an '01 Z06, my father has an '04 Z06, and my mother a '99 MN6 vert... they all have a sewing machine like noise to some extent. It's the nature of the beast.
I'll be installing a G5-X2 cam in mine w/ comp 921's and I fully expect more valvetrain noise... it's not a problem to me.
Old Dec 20, 2006 | 04:02 PM
FKING1's Avatar
FKING1
No tickee here with Comp Cam singles.
Fred
Old Dec 20, 2006 | 04:19 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
G5X4 cam (24x/24x XE-R lobes on a 111 lsa), PRC dual springs, 7.425" pushrods.
Stock heads, lifters, rockers, etc. (for a limited time ).
Engine is very quiet, no ticking. Inside the car with radio off, if you focus really hard, you can detect a faint "sewing machine" sound...but it certainly isn't obvious or noticible.
I was actually surprised at how quiet it was when I first drove it after the cam swap.
Of course I can never be content, so the car is in the process of being torn down again to flycut the pistons, and put on some stage 2 TEA 5.3 heads, GMPP "caddy" lifters, ARP studs, .040" Cometics, and probably some adjustable roller rockers.
Old Dec 20, 2006 | 04:33 PM
Dirty Howie's Avatar
Dirty Howie
I tick mostly at 1700 RPM. Below and above I don't hear it much at all.
Comp Cam and AFR Heads...........
DH
To why do cammed LS1s always tick?
Old Dec 20, 2006 | 07:55 PM
mvvette97's Avatar
mvvette97
well mine had a small tick after I got the cam in with the 918 springs but since I put the duals it got alot louder
Old Dec 20, 2006 | 08:22 PM
bcseitz's Avatar
bcseitz
Mine sounds like a sewing machine. And I have a baby cam, 918's with stock lifters.
I'd like to know more about these Cady racing lifters.
Old Dec 20, 2006 | 08:33 PM
vettenuts's Avatar
vettenuts
Its not the springs. I have run both duals and now PSI beehives, no noise from either. What is the lobe of your Comp Cam?
