Encouraging. But I haven't heard anyone doing a retrofit with these to quiet down their valvetrain. If you do this and it works please do a post so we can all benifit. And please pm me about it as well.
I also believe the only solution to this problem is a lifter swap and lastly, only if necessary, a stronger oil pump. It's got to be because of the aggressive cam profile and extra spring pressures that the stock lifters aren't getting "pumped up" enough.
How soon are you going to try the new lifters?
Bob
What's the latest on this?? I just installed MTI's Stealth II cam in my 2001 Trans Am and I'm getting the sewing machine noise. Are the Caddy lifters the correct choice for proper oiling of the lifters, keeping them pumped and reducing the noise? Please advise!!!
I have the Baby Of All Cams, as Sadaam would say (212/218, .530 lift) and Comp 915 baby springs.
It goes ticky-ticky like a little sewing machine, and I actually love the sound.
However........
I have one REALLY bIG sewing machine in there that ticks louder than the other 15. DRIVES ME CRAZY. Makes me think maybe I did something wrong, or something is coming loose. It's done it for 5k miles now with no change, and I have checked all the rockers, PR's, springs, so I guess it may not be serious.
But why would one valve ticky-ticky 6 times/second louder than the others? AAAARRRRRG.
I fixed my sewing machine. I replaced an ill fitting Stainless Works header.
As it turned out the pass. side header was made incorrectly. The collector was too far towards the passenger side of the car causing the foward O2 sensor to rest on the pass. side floorboard frame. Since threre was total metal contact from the engine, through the header to metal frame of the floor, the valetrain noises were being transfered down through and into the car. Go figure.
I can still hear the lifters. It's not as quiet as stock but it's barely even noticable now.
when I had my H/C installed it sounded like a dang sewing machine and I really hated it! I changed out the stock length and went to 7.425" along with LS7 lifters and now sounds like stock! Well, at least the valve train does. The exhaust and rumble sound with the new H/C is just how I like it!
I had a head and cam package installed with all of the new guts as well, dual springs, rockers, pushrods, valves, dual chain timing. My builder warned me that the drivetrain would produce more noise but that it was still bullet proof, just alot stiffer moving parts to produce more power.
I have about 5k miles on the install and either my hearing is going or the noise just dosent seem as loud
when I had my H/C installed it sounded like a dang sewing machine and I really hated it! I changed out the stock length and went to .725" along with LS7 lifters and now sounds like stock! Well, at least the valve train does. The exhaust and rumble sound with the new H/C is just how I like it!
I'm assuming the LS7 lifters are taller and require the shorter push rods?
I am hearing tht all these ticks are normal because of the ramp rates but I just don't understand what is exactly making the noise. And yes it did sound louder after I put the headers on but it was still kinda loud even with the manifolds. As said above, could it be that the stock lifters can't hold the spring pressure of the stiffer springs??
After I did my H/C, I used the stock lifters, and there was no noticable difference in "ticking" sounds. Now I put in the Caddie racing lifters,along with the roller rocker arms, and it's no different. This is with 7.7" pushrods.
Just wondering, you guys that say yours is quiet, are you running a single or dual spring?
Im runnin a Comp Cam with XER lobes and have dual valve springs. My car cold sounds like a sewing machine. Once it gets warm though it is a little quieter. As someone else said it doesnt bother me a bit. If its not makin any noise its not man enough.
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Originally Posted by Y2Kvert4me
G5X4 cam (24x/24x XE-R lobes on a 111 lsa), PRC dual springs, 7.425" pushrods.
Stock heads, lifters, rockers, etc. (for a limited time ).
Engine is very quiet, no ticking. Inside the car with radio off, if you focus really hard, you can detect a faint "sewing machine" sound...but it certainly isn't obvious or noticible.
I was actually surprised at how quiet it was when I first drove it after the cam swap.
Of course I can never be content, so the car is in the process of being torn down again to flycut the pistons, and put on some stage 2 TEA 5.3 heads, GMPP "caddy" lifters, ARP studs, .040" Cometics, and probably some adjustable roller rockers.
YOU GO TOM,
You know have the GO FAST MODS to match the KILLER cosmetic looks on your beatiful C5!
