C5 Climate Control dim/dark display fix
Old Apr 9, 2010 | 08:07 AM
  #261
Mark Markel's Avatar
Mark Markel
Cruising
Wow!! Thanks for the great FIX. Although when I see circuit boards my short hairs stand up but I've soldered before and worked with boards in the past so I should be able to take care of this. I'll work on it and let you know the outcome. Great rundown and thanks again.
Old Apr 26, 2010 | 08:17 PM
  #262
diverguy70's Avatar
diverguy70
1st Gear
Default this fix was excellent
thanks so much for this forum..fixed my control unit..removed and took it to a great auto-stereo shop..soldered it for $20..works great..loved saving the cash..also on this forum was some great advice for changing front turn signal bulb..dealer wanted $130...cost me about $5 for TWO bulbs..lovin it...P.S. while console was removed had the show wire in an IPOD jack to the radio and into the console for $150..am really pleased...thanks again..
Old May 8, 2010 | 12:19 PM
  #263
GCubed's Avatar
GCubed
Default Fixing the resistors
I just completed this repair and wanted to share some info. I have the second variation with 8 241 SMD in the center. They are in parallel an the outside of each resistor is connected to each other, and same for inside.
By using a meter, I touched an outside resistor between the board and the resistor, then touch the top of the remaining resistors lightly with the probe to ensure each read zero ohms. If you had an area fluctuate then press harder with the probe and see if it goes to zero ohms. If so that is a bad joint.
Then go to the inside and test each joint in the same manner.
Turns out I had two bad joints and resoldered them. I did not use additional solder, instead, I pressed the resistor down with a tool, and then applied the solder iron for a short period to resolder the joint. Seems to have worked fine, with no distortion to the board lacquer.
I think the board flexs too much and the solder joints are not as good as most of the other components on the board.
My unit would work early when car was cooler, and not work when hot.
Great thread! G
Old May 10, 2010 | 10:28 PM
  #264
sk7's Avatar
sk7
Thanxs to all who contributed to this thread. My display was also dead, its the second generation kind, and I couldn't see anything wrong with any of the 241 chips, even with a magnifying glass. They were not loose or moved at all...
I redid all the joints using a bit of flux to help the solder, did not add any extra. Works like new!
It was a good opportunity to clean all the buttons in there as well. Looks like a large french moka coffee ended up in there!
Old May 11, 2010 | 07:45 PM
  #265
MY1STPEWTER's Avatar
MY1STPEWTER
Add 1 more happy camper too the list. Mine had been going dim lately and then nothing. Came across this thread and honestly was hoping there was an easier fix, but since I had put a B&M shifter several years ago I did know I could do part of it. I believe the hardest part was pulling the power cord out of the back, man that sucker was in there.
I've never had a solder iron in my hands until this afternoon, just took my time and hallelujah it worked!!! Sure is nice to have it back working again. Thanks for the thread!!
Old May 17, 2010 | 11:01 AM
  #266
dugsvette's Avatar
dugsvette
2nd Gear
Bought my 98 three years ago and watched display fade out---was saving for a replacement when I started researching alternative repair sources....Pulled mind out last night and fixed it following suggestions on this site...Works great now. I used a 15 watt radio shack soldering iron with a pencil tip and a little flux and just a very very small amount of solder on the tip to help joint re-flow. Took longer to pull the unit out of the I/P than to fix the resistors. Thanks a lot. Saved a bundle.
Old May 31, 2010 | 08:18 PM
  #267
stevenm357's Avatar
stevenm357
awesome post, just fixed the 2001 i bought. absolutely awesome.
Old Jun 1, 2010 | 02:51 PM
  #268
flynhi's Avatar
flynhi
Are there any soldered in components that affect the EXT TEMP display?
My ext temp reading is erratic - upon startup, it runs down to 15 or so then back up to about 20 degrees below true ambient. When I disconnect the sensor, the reading on the Dual control unit stays the same. So, I think the problem is inside the control unit.
This means that the AC doesn't work when the control unit reads below 34F. Gotta have AC in Texas in summer.....
I'm hoping that repairing a solder joint or two inside the unit will fix this.
Any ideas out there?
Thanks mucho.
Old Jun 1, 2010 | 03:37 PM
  #269
lucky131969's Avatar
lucky131969
Thanks mucho.
If you disconnect the sensor, the control panel will default to a set reading.....56 degrees if I recall.......so disconnecting it tells you nothing. The sensor is at a high resistance when the temperature is cold, and low resistance when warm/hot. If you are reading low ambient temps on the display, the there may be a high resistance connection at the plug, or high resistance to ground. I would evaluate the resistance to ground at pin B(Gray/black stripe wire), and check for 5 volts at pin A(light green/black stripe wire).
You can also measure the resistance of the sensor itself, and compare it with the values in the service manual.
Old Jun 1, 2010 | 04:16 PM
  #270
flynhi's Avatar
flynhi
Thanks, Lucky.
I read somewhere on the CF that the unit defaulted to 69F if the sensor is disconnected but that's not happening for me.
I'll check as you suggested.
Old Jun 1, 2010 | 04:46 PM
  #271
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
The HVACs I've benchtested all read 69, BUT that's without any BCM inputs or anything... So I wouldn't say for 100% that uplugging the sensor will place the external temp in defualt @ 69 degrees...
You're in excellent hands with Lucky... Listen and learn!
Tim
Old Jun 1, 2010 | 07:22 PM
  #272
flynhi's Avatar
flynhi
I have .5 ohm in the ground wire and 3 volts in the green black to ground with engine running and with key on, engine off.
I have tried two replacement sensors.
At last startup, the DCC read -15F.
Any ideas appreciated.
Old Jun 1, 2010 | 07:47 PM
  #273
lucky131969
Are you backprobing the connector, or measuring the contacts with the plug disconnected. Reason I ask...you are dropping 2 volts.
Also curious what resistance is measured at the sensor itself. According to the table, it should be around 7000-8000 ohms.
Old Jun 1, 2010 | 10:19 PM
  #274
flynhi's Avatar
flynhi
I measured at the harness connector with the sensor detached.
Does the low voltage mean the DCC unit is sending out a voltage that is too low for the sensor to work?
I'll check the sensor but I get the same result with two sensors - one several years old and one brand new - both GM parts.
Old Jun 29, 2010 | 04:23 PM
  #275
bullonwallst's Avatar
bullonwallst
Default Hvac is Dim, but heat also does not work?
I bought the C5 with a already Dim HVAC. I have not had to use the Heat until the other night when the targa was off and it got cold out. I tried turning on the heat but nothing came out? I also tried using the A/C, but nothing again.
Does this have anything to do with the display unit or is it something else. I know it also was showing 169 degrees for outside temp on the display? Any input would be great.
Thank You
Old Jun 29, 2010 | 08:45 PM
  #276
sk7's Avatar
sk7
When my display was dim-dark it did not prevent AC-heat or fan to work. Just didnt know exactly where or how it was set at. Something else must be wrong.
Old Jul 17, 2010 | 05:22 PM
  #277
cardodger's Avatar
cardodger
1st Gear
thanx for the info worked very easy
To C5 Climate Control dim/dark display fix
Old Aug 4, 2010 | 09:39 PM
  #278
Relsek's Avatar
Relsek
I just did the fix, it was ugly but it worked.
Old Aug 5, 2010 | 08:14 AM
  #279
Mark Markel
Cruising
Thanks Relsek for the latest thread. I've been so busy that I haven't got around to fixing but I plan too real soon. Glad I asked the question and great forum. On another note I have a 79 and plan to change to a high performance shorter starter. I'd be interested to see if anyone has done that. Thanks again, Mark
Old Aug 23, 2010 | 08:30 AM
  #280
black69gto's Avatar
black69gto
1st Gear
Default Worked for me too!
Thanks for posting tips like this, it saves us all a ton of hassle at the dealer and some $$$ too!
BTW, RadioShack does have 12V/60mA lamps still, but they only carry 3 packs (2 bulbs) per store. Had to hit 3 stores to get enough bulbs and they are not listed on their website.
I had both the dim display (fixed by resoldering the resisters) and the burnt out bulbs. Any original bulbs I had popped when I started replacing the bad ones. Its all good now!
