C5 Climate Control dim/dark display fix
Old May 29, 2009 | 09:00 PM
  #221
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Correct, the outer row is 1 - 16, you've got it!
The display board is held into the faceplate by the rear portion of the case, no screws...
Let me know how your test turns out. I use an ESD safe hot air gun when re-flowing the SMD resistors for the display, usually there is suffiecent solder there to work with. It appears to me that the problem is a cold solder joint versus an insufficient amount of solder...
Tim
Old May 30, 2009 | 06:58 PM
  #222
rockinSeat's Avatar
rockinSeat
It was the resistors just as Tim said. I pressed on them while the unit was plugged into the car and the display started to come back. So this time my friend used a 40 watt iron and some good 'ol lead-based solder.
Just held the iron on one corner of the resistor for a second or so, tapped the solder wire against the iron tip to get it running, returned the iron to the corner, and set the wire on the other corner of the resistor -- the solder flows towards the heat in a nice bead along the edge of the resistor. All of these movements have to be performed very quickly to avoid overheating the board or any components, and to avoid using too much solder. Have fun when the 241's go sliding all over the board.
I'm going to practice on some old junk before I work on the power door lock problem.
Thank you all for the help and this great fix. Now, onto the locks, lumbar bags, rocking seats, and key fobs.
Old May 30, 2009 | 10:59 PM
  #223
tstar's Avatar
tstar
Cool beans!
Yeah doing it that way can be a three hand job, like you said if you tap one end and the other side is loose, away it goes like a damn hockey puck! I do alot of these as well as LED mods so I bought a soldering station with a desolder gun, a Hot Air gun as well as a precision pencil sodlering iron all adjustable... The hot air gun makes it MUCH easier!
One thing to keep in mind for the future, I believe the solder used by the manufacturer contains silver and adding a different type of solder may create problems in the future, which could be compounded if he used a flux core eutectic tin/lead solder which is the defacto solder for everyday work. Flux is corrosive and must be removed with alcohol after reworking the components. So keep an eye on it if you can...
Tim
Old Jun 5, 2009 | 12:07 PM
  #224
biglite351's Avatar
biglite351
Does this just work for the buttons, or does it fix the display (whenre the temp etc shows) as well?
Old Jun 6, 2009 | 02:57 AM
  #225
tstar's Avatar
tstar
Just the Center Display Screen. If you have bulbs burnt out you need to replace all 14 at the same time, trust me on this... All of them!
Here are good replacements;
http://www.mcmaster.com/#1505k414/=270i54
Another more permanant and customizable option is to swap the stock incandescent bulbs with LEDs, but I may be biased!
Tim
Old Jun 7, 2009 | 01:41 PM
  #226
Busdriver1's Avatar
Busdriver1
8th Gear
I recently bought a 2001 and it had this problem. I used your fix and although my soldering is not pretty, it worked great. Thanks for the information and the photos.
Old Jul 2, 2009 | 03:30 AM
  #227
jdmvette's Avatar
jdmvette
Night Owl for life
just found this thread. looks like i'll be attempting to do this mod this weekend. is a cold solder iron necessary or would a hot one @ 15w be ok?
what am i actually doing to those 241 chips? re-attaching them to the board?
Old Jul 2, 2009 | 03:36 AM
  #228
tstar's Avatar
tstar
15 Watt with a very fine point would be perfect... I use a Hot Air reflow gun and do not need to add solder, there is enough there, it's just a "cold" joint and subject to cracking and failing...
I suggest that you get some of the new water soluable flux and put a light coat on all the joints and then hit em with the iron. HOLD down the chip while reflowing it so it doesn't go scooting across the board.
HTH
Tim
Old Jul 2, 2009 | 03:52 AM
  #229
jdmvette's Avatar
jdmvette
Night Owl for life
HTH
Tim
can you buy that flux at the shack? if i hold the chip wouldnt it get too hot to touch and therefore require a cold solder gun?
Old Jul 2, 2009 | 03:58 AM
  #230
tstar's Avatar
tstar
I'm not sure RS has it or not, I would think a larger store should stock it... If you can't find some it's no big deal, use regular flux and clean the area afterwards with rubbing alcohol.
Hold it down with a screwdriver or something... and run the iron up and down the joints on each side kinda like painting it. You want to get the solder to flow all through the joint. I'm not a fan of the "Cold" Iron which actually heats up to a temp much higher then some components can handle...
FYI the Cold iron DOES in fact heat up very hot, it just does it instantly and cools down very quickly... There's not a lot of control with it at all. Stay away from it IMO...
Tim
Old Jul 2, 2009 | 04:28 AM
  #231
jdmvette's Avatar
jdmvette
Night Owl for life
^cool.
Old Jul 16, 2009 | 05:40 PM
  #232
Echo's Avatar
Echo
I just bought my 03 ZO6 a week ago and had this problem. I thought I'd remove the unit and send it in to ABSfixer but the more I read about it I decided I'd try it myself. Guys, this is an easy fix. I haven't soldered since college (10+ years).
Radio Shack grounded 15w iron $10.99
R/S 62/36/2 Rosin Core Solder $4.00
I've never pulled a dash or any part of it before. I took my time and the whole job took me about an hour and a half. It feel good to have done it myself. Thanks to all who contributed to this thread and a big thanks for the pictures.
Old Jul 26, 2009 | 09:52 PM
  #233
ragtopcruiser's Avatar
ragtopcruiser
3rd Gear
Default Worked for me!
I had recently purchased an '02 convertable and the climate control unit would dim and I would tap it until it brightened again...eventually this didn't work anymore. I found this thread, followed the directions exactly, and the CCU now works perfectly. Thanks for the excellent thread!
Old Aug 26, 2009 | 05:18 PM
  #234
bogspores's Avatar
bogspores
Wow, you guys just saved me a ton of money!.....
Where there was darkness, now there is LIGHT!....
What really amazes me is how many of us have experienced this fault, and yet why hasn't GM recalled and fixed a known issue like this?
It's obvious this problem was "pre-existing" and not the fault of the user, right?
Many thanks again!
Old Aug 26, 2009 | 08:06 PM
  #235
GKrenn's Avatar
GKrenn
who was the Ebay merchant?
Old Aug 26, 2009 | 08:13 PM
  #236
tstar's Avatar
tstar
Many thanks again!
Correct, it's a production issue. nothing you could've done to create it.
There are several on EBay that offer HVAC repair services as does supporting vendor JW Motoring...
Tim
Old Sep 9, 2009 | 10:00 PM
  #237
ZEX-Z's Avatar
ZEX-Z
wow...very in depth. I am doing mine tomorrow.
To C5 Climate Control dim/dark display fix
Old Nov 6, 2009 | 08:41 PM
  #238
Chrisrokc's Avatar
Chrisrokc
Where can you get the resistors? I broke one of mine during the fix
Old Nov 6, 2009 | 08:48 PM
  #239
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I think I have ONE on my desk at work... You need to figure out what the resistance of it is. Then you can order one from a company like Digikey. Radio Shack may have them. I know a local electronics supply house will have them by the package. They usually come 10 in a pack
Old Nov 6, 2009 | 08:56 PM
  #240
Chrisrokc's Avatar
Chrisrokc
Haha! Well looks like I will have to remove it all from the car again tomorrow to check, unless someone already has the info
