any1 running 2 catch cans??
Howie, I honestly thought you had ordered one a short while ago. If we can round up another 10 people who want them, I'll order again. Lead time for the aluminum cans is about 2 weeks. The filter (with zinc can) takes about 1 week to get here. Since there is an additional price break at 10 pieces, I am throwing in the brass tube fittings and thumb screws to mount the filter to the bracket. The only things the end user will need are sheet metal screws (if mounting to the front cross beam), fuel line, and hose clamps.
Dave
Dave
Have the other guys installed and tested?? Any locals??
I'm going to check out Charlies can but please don't forget me again
DH
It looks like you, Kln and PDD are interested, so I will let you guys know if I can get a few more added without incuring extra cost for lower quantities.
Dave
The only down side is that you should change the oil every 2k miles after which most people should do anyways if your hard on the car.
And yes,we did test hp differences and how the vacuum from the PCV helps the engine seal ect.On a NA 400-500hp car it made no difference at all.Only thing better is a vacuum pump setup.
What about oil smell and leakage from the breathers.
If oil needs to be changed every 2K how about running good dyno oil instead of synthetic to keep the cost down??
DH
As for oil changes I haven't heard any complaints.Of course these setups are on motor with $8k -$40k into them so $50 every 2k miles isn't much for maintanence cost.
Secondly, the true coalescing filter is assembled in series with the particulate filter. This coalescing filter can trap oil aerosols down to .01 micron. Grade C filter (Wilkerson designation) elements are used when the air has to be "oil-free". Critical air control circuits, air logic systems, flow and temperature controllers, food processing, electronics, health care and film processing are some critical end-use "recipients" of oil-free air. Most of our LS1s would not be included in a list such as this.
Also, if oil odor needs to be removed, there are activated carbon element filters are available, making up the third line of defense for such applications. Obviously, this type of filter is a bit overkill for our requirements.
So yes, there are filters than trap all of the oil on its way to the TB, but for the average C5 owner, only one is likely to be necessary, and as was mentioned previously, a common "catch can" is probably not the best solution - better than having nothing, but not optimal.
