broken inner valve spring
Old Dec 31, 2006 | 04:44 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default broken inner valve spring
Is there any way to tell without taking the spring off? It seemed to start ticking on the drivers side after I hit 6k the other day. I looked but can't see anything. Are the inner springs prone to breaking more than the outer? They are Patriot Golds
Old Dec 31, 2006 | 12:49 PM
TYSON1997's Avatar
TYSON1997
All I have ever seen personally is cracked ones. And you can usually turn the motor over and watch and listen and pinpoint which one then use a flashlight and find it. First thing is to pull valvecovers just to see what the hell is going on. Usually I see outers break theyre more susceptible to coil bind and are much tighter.
Old Dec 31, 2006 | 01:00 PM
mvvette97's Avatar
mvvette97
I have the valve covers off and the outer springs look fine. I have a tick on the drivers side but don't see anything wrong.
Old Dec 31, 2006 | 01:31 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I have the Comp 921's with my cam and they tick as well. Unless it is a significant tick i dont think its anything to worry about. Cam only or heads/cam cars typically sound like sewing machines because they tick. I believe they tick because their is increased spring pressure when hitting the retainers. Maybe others can chime in?
Chris
Old Dec 31, 2006 | 02:04 PM
dtc's Avatar
dtc
4th Gear
you might want to check your push rods on that side. may have bent one. if you want to check the inner spring take a small punch or something like that and push on the inner and see if it moves at all
Old Dec 31, 2006 | 02:10 PM
fsuforever's Avatar
fsuforever
i would highly doubt u have a busted valve spring by revving it to 6k .jmo I also have a set on my car along with a 605 lift cam on the exhaust side & rev to 6500 with no issues
Old Dec 31, 2006 | 02:16 PM
see5's Avatar
see5
I broke a few older Lunatis but they were always outers.
Old Dec 31, 2006 | 03:05 PM
vettenuts's Avatar
vettenuts
I posted over on LS1Tech, you seem to be having a lot of valve train issues. Is the one that is ticking in the same place that the 918 previously broke? I am wondering if you have an oil starvation issues possibly due to some dirt or something sitting on top of the lifter.
Old Dec 31, 2006 | 03:28 PM
mvvette97's Avatar
mvvette97
yea, I really don't think I have a oil problem. I'm starting to think I should of left it stock. It's my wifes car and she is getting pissed. I did find out that my pushrods are too short so I bought a set the correct length. I HOPE!! that will fix it. If not I'm going to pull the heads and take a look at the cam. If the cam is fine I already have a new set of lifters that I will put in. I really can't imagine that the cam is bad. I bet I only have the max of 1500 miles since the swap. I guess I am getting things figured out though. I did find out that the original 918 springs were defective. And I did find out the base circle of my cam so I know that I do need the 7.425 pushrods. If I can't seem to get it fixed you wouldn't know of a big cliff around do ya?
Old Dec 31, 2006 | 03:30 PM
mvvette97's Avatar
mvvette97
you have been alot of help since you have fallowed my problem from the git go. It has been a royal pain.
Old Dec 31, 2006 | 03:40 PM
vettenuts's Avatar
vettenuts
When you change the pushrods, look into each lifter with a strong light and make sure the top of the lifter doesn't have any debris on it at all.
Old Dec 31, 2006 | 03:47 PM
mvvette97's Avatar
mvvette97
I'll do that. I ended up buying the set of pushrods that I sold to a forum member. Guess I should of kept them
To broken inner valve spring
