Spark Plug Wires?
Old Jan 2, 2007 | 11:45 PM
Corvette Don's Avatar
Corvette Don
Default Spark Plug Wires?
I broke 4 of mine pulling them off (7 years old), does it really help to get the MSD's or should I just go buy the stock ones?
Old Jan 3, 2007 | 12:05 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
go buy stock MSD sucks! or get some wires from LGM they may be Taylors.
Old Jan 3, 2007 | 12:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The very best bang for the buck is the RED GM performance wires! Very good quality! Thats what I would get if I had to get wires again. I have an 06 and it has the red wires! Dont know if they cross over to C5 or not. I think they are like $40 ish dollars.
BC
Old Jan 3, 2007 | 08:27 AM
Corvette Don
Did you get them from the dealer?? Where?
Old Jan 3, 2007 | 08:31 AM
Tigershark3's Avatar
Tigershark3
I got mine from Forum Vendor - Fred Beans.
Old Jan 3, 2007 | 08:36 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
BC
, these are the ones to get
Old Jan 3, 2007 | 08:37 AM
Corvette Don
Can I get them from the dealer??
Old Jan 3, 2007 | 08:44 AM
SteveDoten's Avatar
SteveDoten
even better
www.gmpartshouse.com
Gene Culley will have these on your doorstep for less $$
Old Jan 3, 2007 | 10:38 AM
zeevette's Avatar
zeevette
I don't know why that guy always ranks on MSD. I called Thunder Racing and asked them what they recommend, and not only did they say MSD, but they were quite a bit cheaper than other brands they sell. Look and work great for me.
Old Jan 3, 2007 | 10:49 AM
426 Hemi's Avatar
426 Hemi
pn: 12495519 $45 good guy price.
Old Jan 3, 2007 | 11:51 AM
Bubbletop409's Avatar
Bubbletop409
Every NHRA Pro Stock car is equipped with complete MSD ignition systems. These teams have very deep financial resources, and you can rest assured if there was something better out there, they would be using them.
Old Jan 3, 2007 | 12:01 PM
John Shiels
They are running the same wire as a Corvette? The MSD wires are horrible because you can't feel them snap on and the rubber boot on mine cracked and was causing a miss firing and they were new. The stockers when 55,000 miles no problem. MSD is junk. You want pictures I'll post as I have before.
Old Jan 3, 2007 | 06:00 PM
Bubbletop409
Well I guess it's possible for someone to have a bad experience with a companies product, but on the other hand I have used various MSD products for 20+ years with zero defects. The list would include wire sets, crank triggers, timing computers and retards, 3 steps, rpm limiters, 7AL boxes, etc. Have had their stuff on two boats, two race cars, and three street cars, would never think of looking to another company for ignition products.
Old Jan 3, 2007 | 08:12 PM
John Shiels
new wire that had a kool sox which the stocks ones never had
http://shielsmasonry.com/MSDJUNKWIRE.jpg
http://shielsmasonry.com/MSDEND.jpg end clips on like crap and doesn't stay on. Burned my hands at track trying to keep putting them on. Car was misfiring and ruined 5 track days. I even had my mechanic put them on and it was the same crap. Others on the forum have had similar problems.
Old Jan 3, 2007 | 08:44 PM
vetpet's Avatar
vetpet
The GM red wires are very good and priced reasonably. I've used MSD's, Taylor, Accel and others over the years and they've been good also but if you've had one bad experience with any make then you might not have a good opinion to offer. Stick with the GM set and just make sure you snap the plug boot on good. Apply a bit of dielectric grease inside the boots before installing and listen for the click when installing them.
Old Jan 4, 2007 | 01:08 AM
Bubbletop409
[QUOTE=vetpet;Apply a bit of dielectric grease inside the boots before installing and listen for the click when installing them.
[/QUOTE]
I first learned about dielectric grease when I bought my first set of wires way back when. It is an important step in installing the boots on the plugs, acts as an insulator and a lubricant, also makes removal easier after many miles.
JOHN that first picture you posted looked like a rat had been chewing on the boot. It's hard for me to imagine how that type of damage could result from normal use and installation
Old Jan 4, 2007 | 01:24 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Jacob's wires puts them all to shame .They are the best wire on the market and still less than a hundred bucks They go on both sides with a snap.
They are owned by Mr Gasket.
Who also makes all the Accel stuff.Along with Hurst products.
Gm wires are ok but don't pass near the current though the wire.
To Spark Plug Wires?
Old Jan 4, 2007 | 11:07 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Magnecore. Nobody compares their wires to them unless they want to come in second place. For the price you can't beat the stock or GM red wires.
Old Jan 4, 2007 | 02:31 PM
3 Z06ZR1's Avatar
3 Z06ZR1
This is nothing new, your points are valid.Used read about people with poor Msd wires on the Old Ls-1 .com. I 've put on the Msd's before and they are not close to the stock or Jacob's.
Old Jan 4, 2007 | 03:08 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I also had a horrible experience with MSD wires on my Vette, I installed a set after I changed a cam then on start up the engine ran rough and was throwing a P0300 code we turned the lights down in the garage and it looked like a light show under the hood, every single plug wire was arcing to the headers.
