head removal 2000 Vette
Old Jan 4, 2007 | 06:39 PM
calvette 11's Avatar
calvette 11
Default head removal 2000 Vette
I'm ungrading to Patriot Heads.Do I need to remove the power steering pump to remove the driver side head,or can the pump be disconected and removed as one piece.If the pump must be removed first,how is it done?
Help is needed.
Old Jan 4, 2007 | 08:08 PM
TYSON1997's Avatar
TYSON1997
the whole bracket will come off with the alternator, power steering pump still on it. disconnect lines from rack and pinion and cooler and remover whole bracket.
Old Jan 4, 2007 | 08:54 PM
easyvette's Avatar
easyvette
LS1howto.com
Old Jan 4, 2007 | 09:03 PM
vettenuts's Avatar
vettenuts
No, only the alternator. No need to remove or open the power steering system. Once the water pump is off (along with the alternator) the bolts are easy to get at to remove the bracket and push it out of the way. I tied a string to it to hold it forward out of the way of working on the block.
Old Jan 4, 2007 | 09:05 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If it's just a head swap...
The PS pump is bolted to the alternator bracket.The alt. bracket is secured to the head with 4 screws. Getting to the inner ones with the water pump in place is a PITA.
What to do, instead of draining coolant and removing the water pump, get everything else needed to remove the heads off (intake, headers, eyc), unbolt the head, lift the head up as far as you can off the block, then remove the alt. bracket from the head. The pump will stay attached to the bracket. No need to disconnect the PS lines, they have enough slack to unbolt and set the pump/bracket aside.
Old Jan 4, 2007 | 09:23 PM
willyfastz's Avatar
willyfastz
I would just rent a puller from Advance and pull the pulley from the PS pump and pull the pump off the bracket. That would be the easiest thing to do.
Old Jan 4, 2007 | 10:42 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the plastic pulleys often are destroyed when removed from the pump, I've had them off without breaking, but seems they often crack
I'd remove the 4 15mm head bolts and disco the 2 lines to the rack(18mm flare wrench), remove the whole assy
pass side head: bolt for the wire harness
driver's side head: ground and AIR tube bracket(only loosen, notched fit)
ARP head studs and GM MLS gaskets for the install
Old Jan 4, 2007 | 10:56 PM
calvette 11
Default heads
I will try to take it off,by lifting the head after removing the bolts.I will everybody know if sucessful.
Thanks to all
Old Jan 5, 2007 | 06:00 AM
vettenuts's Avatar
vettenuts
Pull the water pump first, then suck the coolant out of the block, then pull the heads.
You don't have to pull the water pump, but be ready for a big mess to clean up (coolant in cylinders, on the floor, in the head bolt holes) and make sure you get absolutely all the coolant out of the bolt holes for the heads. I pumped my block dry through the water pump holes and only got a couple of drops of coolant that splashed over the exhaust side of the block when I lifted the heads.
Old Jan 5, 2007 | 02:12 PM
94legaleagle's Avatar
94legaleagle
Yes, but then try and get that pulley back on - I had to put a new pulley on my '01 - lucky the entire car was apart, cause it took an impact wrench and grade 8 bolts to push the new pulley on the power steering pump - it was a BI###### and then some.
Old Jan 5, 2007 | 10:32 PM
calvette 11
Thanks to all
I unscrewed the three bolts from the bracket to the heads.I caught hell
with the ground wire and the ERG bolts in the rear.What is a good way to get the water out of the bolt holes.These head gaskets go on dry
or sealer around the the water jackets
Old Jan 5, 2007 | 11:15 PM
SteveDoten's Avatar
SteveDoten
Originally Posted by calvette 11
Thanks to all
I would suggest buying the shop manual from GM and reading www.LS1howto.com a few times, leaning more towards the shop manual
LS1 Corvettes do not have EGR, that is the AIR injection pipe
cleaning the bolt holes of any material or coolant is critical
Old Jan 5, 2007 | 11:34 PM
thehammer69's Avatar
thehammer69
Blow compressed air in the holes.
Hammer
Old Jan 8, 2007 | 12:08 PM
calvette 11
Thanks there was more water in the holes than I thought.I quess I would never have gotten the heads tighten properly.The Heads should be here today.I'll let every know how this worked out.
thanks
To head removal 2000 Vette
