HELP: Front Cam Bearing Damage... Please Look!
Old Jan 9, 2007 | 06:33 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default HELP: Front Cam Bearing Damage... Please Look!
Ok... right now I'm pretty much sick to my stomach... this is my frist cam install and I'm scared that I f'ed up bad.
The cam was tought to get out but I went slow pulling and turning etc etc... it got hung up a bunch, but I was patient. At one point it was very stuck then all of a sudden it popped out 4 more inches. I get it all the way out and find that the AC condenser is in the way. So... I easily let the cam hang and get it out of the way, then proceed w/ pulling it out.
Here are the pics... the areas of concern are circeled in red w/ MS Paint and can be hard to see.
Pic 1 the top of the bearing has an odd irregular scratch that can be felt w/ my finger.
Pic 2 the bearing outer edge has two small nicks in it... I'm am unsure if I did these, but they're here now.
Pic 3 the bearing's lead part looks flakey to the right of the 6 o'clock position.
So... can I proceed w/ the cam install? Is this front bearing changeable w/ the motor in the car?
WHAT DO I DO?
Old Jan 9, 2007 | 06:43 PM
tiojames's Avatar
tiojames
Not to worry. You can rent a cam bearing removal tool (puller) to get the old bearing out and either a cam bearing install tool or a piece of wood to tap the new bearing in. Be sure to check the other bearings too.
Old Jan 9, 2007 | 06:45 PM
Cobra4B's Avatar
Cobra4B
Ok... so it can be swapped in car? You're saying I should change it?
How can I check the other ones w/ the motor in the car let alone replace them.
Old Jan 9, 2007 | 07:57 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Brian, that really doesn't look deep enough to affect the oiling of the bearing to me. Maybe somebody has more experience, will tell you more. However, the risk of changing that bearing is probably more than running the original one. IF you're really worried about it just make sure it's smooth, around that edge.
Old Jan 9, 2007 | 08:23 PM
vettenuts's Avatar
vettenuts
The top one is actually a little more concerning than the bottom since it is right in the middle of the oiling surface. How deep is it? Hard to tell from the photo.
Old Jan 9, 2007 | 08:26 PM
Corvette Don's Avatar
Corvette Don
Its a pretty simple swap out with the right tool, I would fix that and not take a chance on it ruining your cam/block down the road!
Old Jan 9, 2007 | 08:28 PM
NSTG8R's Avatar
NSTG8R
mah, slap some jb weld on it and you'll be good to go.
Old Jan 9, 2007 | 08:38 PM
vettenuts's Avatar
vettenuts
Can you see the rest of them? Is this the only one like that?
Old Jan 9, 2007 | 09:21 PM
tiojames's Avatar
tiojames
I would not run a scratched bearing in my car. You can check the other bearings with a long handled mirror. You can change the bearings in the car. The tool has the ability to pull them all out the front if need be. Only problem is if one off the rear bearings is no good you have to pull all the ones in front of it to get it out. Then replace the bearings back to front as you work your way out. There is also a tool to help you hold the cam straight as it goes in and out. It attaches to the front of the cam.
Old Jan 9, 2007 | 09:22 PM
zeevette's Avatar
zeevette
I'd replace the one bearing regardless of whatever else. It looks a little scored in addition to that damage. Good luck.
Old Jan 9, 2007 | 09:25 PM
GotMoJo's Avatar
GotMoJo
It's actually not that bad. The cam rides on a film of oil when the engine is running so most of the scaring occurs during start-up. Put it back together and don't look back.
Old Jan 9, 2007 | 09:37 PM
cruisemon's Avatar
cruisemon
It's not a bad idea to replace the cam bearings if you're swapping the cam. Cam wasn't a ten cent item and another $25 bucks, maybe a few pennies more or less ($23.98 at Rock Auto) is money well spent. Be sure to use a good cam break in lube. If you can find one with molybdenum disulfide in it, that is even better. A thin coat of MoS2 on the bearings and cam bearing journals provides good lubricity at startup.
Charlie
Old Jan 9, 2007 | 10:19 PM
94legaleagle's Avatar
94legaleagle
Brian -
Hope this turns out OK - keep us posted on what you decide to do - I'd have someone who knows a little something take a look at it, and then decide whether to replace the bearing or not -
We discussed it on your other thread, but looks like you found out here, so fill me in: does the a/c condensor HAVE to be moved out of the way for the removal/install of the cam, and if so, HOW FAR? obviously you found out, and I want to learn from your experiences.
Good luck, and keep up posted.
Old Jan 9, 2007 | 11:25 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Your on the money Chris. Just got back from checking it out, it looks alot worse in the picture then it reality, a jewels file to knock off the gouges edges and a little emery cloth for the scratch. Just my QA structural mechanic opinion...BTw when i did my H/C swap this past summer i didn't have to remove my A/C condenser, had enough room after pushing it forward a little to pull the cam out.
Old Jan 10, 2007 | 12:02 AM
Cobra4B's Avatar
Cobra4B
Originally Posted by 94legaleagle
Does the a/c condensor HAVE to be moved out of the way for the removal/install of the cam, and if so, HOW FAR? obviously you found out, and I want to learn from your experiences.
Yes... you can get to the last journal w/ before the end of the cam hits the condensor. I had toe remove my vortex rammer air box so I could pull the shround back a few inches and had my roomate hold the condensor back 2 or 3 inches... no need to remove it.
Charlie it's my understanding after research and speaking w/ tuners that you can use simple engine oil w/ the roller lifters etc. On the modern LSX motor there is no cam breakin, just heat cycling the spings. I plan on coating it w/ Amsoil 5w40 like I use in my motor.
After having mike inspect it I trust his judgement... I will file and proceed w/ his help.
Thanks 1,000,000 for looking at it buddy... I trust your professional experience... now that I look at it I see what you mean about the cam not touching it etc.
Updating my main thread w/ today's pics now.
Old Jan 10, 2007 | 12:03 AM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
smooth the nick out and the scratch isn't on the "load"side of the bearing so it won't be an issue
Old Jan 10, 2007 | 01:15 AM
illmac77's Avatar
illmac77
CI 7-8 Veteran
St. Jude Donor '07
anytime
To HELP: Front Cam Bearing Damage... Please Look!
Old Jan 10, 2007 | 01:55 AM
Tourmgr1's Avatar
Tourmgr1
Emery cloth ??????
Old Jan 10, 2007 | 02:00 AM
illmac77's Avatar
illmac77
CI 7-8 Veteran
St. Jude Donor '07
Originally Posted by Tourmgr1
Emery cloth ??????
emery cloth is used for light metal sanding, removing rust and corrosion from metal surfaces.
Old Jan 10, 2007 | 05:41 AM
vettenuts's Avatar
vettenuts
Bearings require a specific surface finish, if you do decide to use emory cloth I would use something like a 2,000 grit.
