emergency oil issue
Old Jan 9, 2007 | 10:17 PM
LTVetteVert00's Avatar
LTVetteVert00
Default emergency oil issue
O.K. Here goes. :o Took my newly purchased 2000 Vert for a spin and a nice meal with the missus. Drove about 20 miles. When we left the restaurant, the low oil level message came on. I stopped at the first service station I found (2 miles away) and checked oil. Sure enough, it was nearly a quart low. So, I dutifully went in to purchase a quart of 5W30 synthetic oil. But, all they had was Brand X regular oil and Castrol GTX 10W30. Neither were synthetic. Rather than risk running any further with low oil level, I added a quart of Castrol into the engine and drove home. The low oil level message seemed to become intermittent...only comes on at low RPMs. But, it does still come on despite the addition of more oil.
Query - what does adding a quart of non-synthetic oil do to my motor? I reasoned that it was better than doing nothing. Am I correct in assuming I need an oil change ASAP since I have mixed the types of oil? Any ideas on why the low oil level light is still on?
LT
Old Jan 9, 2007 | 10:36 PM
cruisemon's Avatar
cruisemon
I would change the oil. If you just purchased the car, absent proof positive of the last time the oil was changed, I would change it anyway. If it was just changed by someone not knowledgeable, they may have only put in 5 quarts of oil instead of 6 1/2.
It's time to change the oil. Filter too.
Charlie
Old Jan 9, 2007 | 11:41 PM
BATM4N's Avatar
BATM4N
Charlie
You need an oil change and new filter and if you jack up the back end for an hour it will probably take close to 7 quarts.
Old Jan 11, 2007 | 08:00 AM
LTVetteVert00
thanks for good advice. Car is at "Stealership" now. I wonder if they will use the oil I provided??? We will see just how competent they really are...LT
Old Jan 11, 2007 | 08:19 AM
Midwest Vette's Avatar
Midwest Vette
Charlie
Old Jan 11, 2007 | 08:21 AM
Billdog350's Avatar
Billdog350
There are tons of threads on filter choices, make sure they don't use regular FRAM's...they're JUNK.
Old Jan 11, 2007 | 08:24 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Had the same problem. Had a 1/2 quart left and topped it off. Don't think that the dealer topped it off with 6.5 the low oil warning will come on for 10 engine cycles then disappear or so it is written somewhere in the forum. Mixing oil? I'd get it outa there.
Old Jan 11, 2007 | 08:28 AM
briann510's Avatar
briann510
Running a qt low wouldnt have hurt anything unless you were racing the heck out of it and oil temps soared. I would have run it low if i couldnt have found a qt of syn for it.
Old Jan 11, 2007 | 03:03 PM
2blklt4's Avatar
2blklt4
Changing the oil is so cheap...why not just do it.
Everytime i get a new car i change all the fluids first...cheap insurance
Old Jan 11, 2007 | 03:08 PM
Dave68's Avatar
Dave68
As an FYI, mixing conventional and synthetic oils will not cause an exothermic reaction and melt down your engine. In fact, synthetic "blends" are just that - a blend of conventional and synthetic oils. Therefore, don't panic about this. Your engine is just fine; changing its oil a little bit early is all you need to do.
Old Jan 11, 2007 | 03:49 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
Old Jan 11, 2007 | 04:32 PM
VetteDrmr's Avatar
VetteDrmr
Ditto. Before you let anyone change your oil make sure they know what they're doing!
Have a good one,
Mike
Old Jan 11, 2007 | 04:45 PM
SLPRC5's Avatar
SLPRC5
K&N Oil filter HP1007 and seven quarts of 5w30 or 10w30 Royal Purple will have it running great. My $.02
To emergency oil issue
