Best location for AIT sensor relocation?
Old Jan 20, 2007 | 05:45 PM
DBLX's Avatar
DBLX
Default Best location for AIT sensor relocation?
Alright GURU's, where is the best place to relocate the AIT sensor? Anyone have pics of their install?
TIA,
DBLX
Old Jan 20, 2007 | 08:10 PM
miami993c297's Avatar
miami993c297
TIA,
DBLX
Here is what I did :
Christian
Old Jan 20, 2007 | 10:36 PM
DBLX's Avatar
DBLX
Thats way off from what I was thinking. I was heading in the other direction for relocation, like near the air filter. Are there any other optimum locations?
Old Jan 20, 2007 | 11:25 PM
Face's Avatar
Face
I placed mine in the hole for the air pump hose in the VaraRam.
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Sure.. An easy one is if you dump the A.I.R. system, simply extend the stock wiring to reach the old A.I.R. fresh air intake (that tube / grommet on the stock or aftermarket air intake system), plug the hole with an appropriate grommet.
That's as far away as you can get and still measure the intake air supply.
Old Jan 21, 2007 | 12:16 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
There seems to be two schools of thought here. Which is better, NO wait! I’ll start a pissing contest. What are the advantages of placing the AIT as far away as possible and placing it as close to the engine as possible?
I understand that one would be reading a colder and denser air charge for performance while the other way would be a more accurate measure of what’s actually hitting your cylinders…
So what are the pros and cons?
Old Jan 21, 2007 | 12:46 AM
Dan_the_C5_Man
Closer to the intake (like in a pre-2001 Honker install) provides the most accurate data for fueling and ignition timing, furthest away will assure ignition timing will not be pulled prematurely..
The reality is ANY location other than stock is "wrong". The PCM's tables were designed around the stock sensor placement.
The closer to the throttle body = higher temps recorded = more likely to pull timing and lean the A/F mixture, further away = lower temps = less likely to pull timing and richen the A/F mixture.
If you have the car tuned, no one location has an advantage over another.
In a stock config, you might gain a very, very small advantage by placing it further away from the TB (2 or 3 degrees of timing will cost you more HP than a .25% bump in A/F mixture).
Old Jan 21, 2007 | 12:56 AM
tstar's Avatar
tstar
In a stock config, you might gain a very, very small advantage by placing it further away from the TB (2 or 3 degrees of timing will cost your more HP than a .25% bump in A/F mixture).
Thanx!!!!
I always pay attention to your responses in here, you've only been wrong twice!!!!
Old Jan 21, 2007 | 01:30 AM
Dan_the_C5_Man
Originally Posted by tstar
Thanx!!!!
Heck, when exactly did THAT happen!
Old Jan 21, 2007 | 06:44 AM
DBLX's Avatar
DBLX
Default Ask first!
Today I was reminded a very important lesson! Ask questions before you spend your cash. Now feel like I wasted my money on the AIT relocation kit. Fortunately, it didn't cost me too much. I can eat this one. Different story if its a cam, heads, etc...
Old Jan 21, 2007 | 08:17 AM
miami993c297
My choice was directly dictated by the heat soak problem related to the OEM location in the MAF for the 2002 ZO6 that was bothering my OLSD tune.
Then I went Mafless and I had to relocate the IAT sensor.
This choice is not better power related or producing any more power by itself but it is simply more accurate...
And the heat soak problem is something I dont' deal with anymore...
Instant response of real IAT from the sensor...
No more LEAN HOT START...
I have seen only advantages, and power stays the same, just tuning will follow all the algorithms inside your VCM.
If the goal is to gain the loss on timing ("power") due to the IAT high temp, go for the $1.29 "Tiristor mod" (Radio Shack).
When I tested it I had my IAT was stuck for ever at 64°...good on one side, very bad on the other...
Christian
To Best location for AIT sensor relocation?
