stuck head light door
Old Jan 22, 2007 | 12:33 AM
highlander's Avatar
highlander
Default stuck head light door
My left headlight door wouldn't stay down. As I shut off my headlights, they both drop down normally but the left one pops back up. I can manually adjust it down but then next time I turn the head lights on, it stays up again. There must be lots of threads on this but my search didn't turn up anything. Oh yes, 2000 coupe, 6 spd.
Thanks,
Old Jan 22, 2007 | 01:35 AM
DeeGee's Avatar
DeeGee
There's a TSB out on that problem. Seems like an easy fix. here ya go:
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the
insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator
Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Old Jan 22, 2007 | 06:06 PM
highlander's Avatar
highlander
Default TSB Locater help
This sounds perfect but I think I need a drawing to proceed. Is their a site that has TSB's you can download.
I did a google search but couldn't even find this TSB.
Thanks,
Old Jan 23, 2007 | 12:35 AM
DeeGee's Avatar
DeeGee
PM me with your e mail and I'll send it. I'm away for the rest of the week so it'll be the weekend.
Old Jan 23, 2007 | 01:43 AM
highlander's Avatar
highlander
Default my e-mail
All the way from the UK, thanks.
cam@moulthrop.com.
Its appreciated.
Old Jan 23, 2007 | 12:04 PM
HollywoodFRC's Avatar
HollywoodFRC
Default All Data
Join Alldata.com. TSBs, Recalls, Manual at your fingertips. Has most current list of TSBs and recalls. Also has a complete DIC Code section with diagnostic and repair instructions. $25.00/year.
To stuck head light door
