doing brakes! question!
Old Jan 27, 2007 | 05:06 PM
dwarmenzerk's Avatar
dwarmenzerk
Default doing brakes! question!
is there a detailed article on how to do the brakes on the corvette? because Im having a hard time doing this.. I got the caliper off, but i cannot seem to get the bracket holding the rotor on, off..
Old Jan 27, 2007 | 05:12 PM
vettenuts's Avatar
vettenuts
Brackets are tightened on with 125 lb-ft with red loctite. You need a breaker bar and some ooommmmppphhh to get them off.
Old Jan 27, 2007 | 05:35 PM
LoneStarFRC's Avatar
LoneStarFRC
Got Wheaties?
Old Jan 27, 2007 | 06:55 PM
1FUNVTT's Avatar
1FUNVTT
If you don't have a long enough breaker bar (I would also use the 1/2" drive socket), then attach a pipe at the end of the ratchet or bar as a cheater.
Old Jan 27, 2007 | 09:36 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i used a 3lb sledge hammer and a box end wrench to get mine off last weekend. they are on there TIGHT.
Old Jan 27, 2007 | 11:18 PM
dwarmenzerk
oh yes, definately tight, i actually was able to get the top one off without using this method described above.. im beeefyy!
Old Jan 28, 2007 | 12:05 AM
jmzvet's Avatar
jmzvet
Make sure you use a wire brush or even better, a wire wheel, to clean the threads on the caliper bracket bolts that hold the bracket/caliper to the spindle. Mine were caked with LocTite. Better yet would be to use new bolts. I've had mine off several times and reuse the same bolts but I'll get new ones next time.
Old Jan 28, 2007 | 09:39 AM
MNCorvette's Avatar
MNCorvette
Default ?
so reinstall with red loctite?
Old Jan 28, 2007 | 10:16 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Yes, and retorque to 125 ft lbs.
Old Jan 28, 2007 | 12:01 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Old Jan 28, 2007 | 02:06 PM
chevyvette1's Avatar
chevyvette1
here is a place to look, gives good info, it's a very easy job, even for me see if this helps you
http://forums.corvetteforum.com/show...m_id=49&arch=1
Old Jan 28, 2007 | 03:27 PM
2000BSME's Avatar
2000BSME
FYI, removing red loctite is much easier if heat has been applied, such as a few seconds with a portable propane torch.
To doing brakes! question!
