Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
I just dropped my car off at the dealership.
On the way the Check engine light came on.
I checked the DTC codes and received a PO300 Engine Misfire.
My car is under warranty and they just installed a new engine so back it goes.
Thanks Jerry
Originally Posted by Jerry D
That doesn't sound too good!
Bad/Good news if that's what it turns out to be. Bad news you've already experienced, i.e. misfires, etc. Good news is it's relatively easy and cheap to repair. Let's hope that's all it is.
Whatever it is my warranty should cover it. This is a brand new engine put in by the dealership under my warranty.
I'll post their diagnosis when I find out.
