HELP ! Failed State Inspection in Texas
Old Feb 11, 2007 | 10:18 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by The Wrench
Toque, Patches just posted the "Magic Elixer" above.
I had been playing with my injectors (looking for a minor tap noise) and set a code. The manual said 40 run cycles to clear.
I went thru Patches' drive cycle twice (on the George Bush Tollway) and the Readiness tests passed, and I got my inspection done.
Give it a try.
DG
Will do ! Thanks guys !
Toque
Old Feb 11, 2007 | 11:36 PM
VetteTech81's Avatar
VetteTech81
Originally Posted by Toque
I just noticed now...
In the report I also show 2x other "Not Ready's"
1.) EVAP - Not Ready
2.) 2nd System - Not Ready
What the heck are those ?
Toque
1. is EVAP which is your evaporative emissions system, basically it takes care of your fuel vapors in your tank.
2. Is probably your secondary air injection? guess which is your air pump that connects to your exhaust manifolds to pump air to help the cats light off..
I wonder why your throwing a lean code for one bank...
Good Luck
-=Rick
Old Feb 12, 2007 | 04:02 AM
Choreo's Avatar
Choreo
Won't help with solving your code problem, but I get inspections done every year in West Texas and they have never checked my exhaust or codes once (nothing to check them with) - I just go to a neighborhood oil quick-change place - always out in 10 minutes?
Old Feb 12, 2007 | 01:49 PM
vince3's Avatar
vince3
Mine passed with the same code.
on my emmssions report it says not ready too.
take it to the Mobile One lube center off of forest ln near 635.
Old Feb 16, 2007 | 09:36 PM
Toque's Avatar
Toque
Guys:
I finally got a chance to go to LG's to get this figured out. Sean hooked me up and I should not get the lean codes anymore. Thanks Sean !
Sean verified that I had 3 "NOT READY" codes (same as report said).
I am now going to follow "PATCHES" GM OBD-II driving cycle procedure in the AM down 78HW (Thanks Patches!). I will then go back to LG's and see if my codes have cleared. If they do then I will go to the dealership and get my safety inspection done.
Wish me luck !
Toque
Old Feb 17, 2007 | 09:31 PM
Toque's Avatar
Toque
Guys:
I passed !
Well Patches driving plan seemed to work (I did it 2x times). It cleared the 2nd system "NOT READY" to "READY". I sill have Not ready for my catalyst, and EVAP. I hope they clear as I drive the car more. Sean at LG's says more Drive cycles shoudl clear it.
It turns out that "Vette-Red" was correct... Your allowed 2x Not Ready's in TX. 3 and you fail.
Thanks guys !
Toque
Old Feb 17, 2007 | 11:14 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Glad to see it all worked out for you
Old Feb 18, 2007 | 11:16 AM
Vette-Red's Avatar
Vette-Red
Guys:
I passed !
Thanks guys !
Toque
Wow, I was right about something.... Glad to help.
Old Feb 18, 2007 | 11:17 AM
Vette-Red's Avatar
Vette-Red
Here in Tx. I wonder if you hollowed out the cats if you could still pass when they plug in the computer?
Old Feb 18, 2007 | 12:23 PM
Toque's Avatar
Toque
I don't know. My catalist still says "not ready". I have Random High flow cats with the LG Pro Long Tube headers. Sean says more driving cycles should clear it.
It may never go to "ready" if you hollow them out... Not sure though.
Toque
Old Feb 18, 2007 | 07:51 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Inspection requirements are different in the counties with the major metropolitan areas. If I lived just 5 miles south, I'd be in Hays county instead of Travis county (Austin), and annual inspection wouldn't be as involved.
Old Feb 19, 2007 | 09:41 AM
1B.DZ's Avatar
1B.DZ
What exactly is a "cycle"? Do we have to do all those steps to complete one cycle? or is it not as involved is that? I keep seeing cycles and I believe it would suck to have to do that 50 times. Someone please clarify for me.
Thanks,
Josh
Old Mar 15, 2010 | 04:22 PM
  #33
Z0ra6's Avatar
Z0ra6
Toque
Old thread, I know......so has anyone passed TX inspection with LG's LT headers and off-road X-pipe? I guess the tests depend on which county you are in.
Old Mar 15, 2010 | 04:51 PM
  #34
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yes, you should be able to pass.
As long as you have no check engine light on, the rear 02 sensors have been correctly tuned out, you haven't recently disconnected the battery, or had to reset a code, it should pass the OBDII test.
Old Mar 15, 2010 | 06:27 PM
  #35
Toque's Avatar
Toque
I have cats with my LG Pro's (rear O2's tuned out). I have never had an issues. They never even look under the car to see if the cats are there. I just run over to my local Quick Lube place to have it done.
Toque
Old Mar 15, 2010 | 11:44 PM
  #36
Millenium Z06's Avatar
Millenium Z06
Moderator
Mine passes every time now, that I know what causes the problem (and I still haven't gotten around to getting a tune done). I had 3 not readys but you can only have 2 and pass. The cats will never read ready unless they are tuned out like Toque did and make sure you have driven it if the battery has been disconnected. Like Y2k said, if you have the backs tuned out since you have no cats you'll be ok unless the tech gets pissy and looks under the car; I went with cats so I would never have to worry about that exact thing and at a cost of 5hp, I dont see why anyone would go thru the hassle of not running cats.
Old Mar 15, 2010 | 11:59 PM
  #37
tommie's Avatar
tommie
yes with my tune i pass...
To HELP ! Failed State Inspection in Texas
Old Mar 16, 2010 | 12:19 AM
  #38
coolbubba's Avatar
coolbubba
I've passed twice with no cats (gutted) and long tubes and going for a third in the next couple weeks. My car still throws a p0420 and p0430 now and then which I have to reset to turn off the CEL-then I have to make it all the way through the drive cycles and haul *** for the inspection station before the codes return. I think a better tune could help me.
Old Mar 18, 2010 | 04:32 PM
  #39
KC2GIW's Avatar
KC2GIW
Again digging up the thread....I'm having a heck of a time getting my EVAP readiness monitor to go away....is there a silver bullet for this too?
Old Mar 18, 2010 | 04:49 PM
  #40
dougbfresh's Avatar
dougbfresh
I assume your gas cap is tight? Evap pulls vacuum on the tank every so often, see if you have an codes in the computer too.
