Rotor Glaze Question
Old Feb 11, 2007 | 08:22 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Rotor Glaze Question
I just put some aftermarket drilled abnd slotted rotors on today. I seated the pads (three step process) according to the instructions. I have about 25 miles on the car now and three of 4 rotors have a glaze on them- only one is nice and clean The pads are Ctech Metallic. I not real happy with the braking...it feels like I'm pushing my foot against a ball filled with air before the car begins to really stop. And the ABS is activating quicker than before.
Im already getting a lot of pad dust. Do you think if I put my old-almost new ceramic pads (have 2000 miles on them), there would be any improvement?
I sort of cheaped out on these pads...I have Hawks on my Caddy and Neon R/T and they have a great feel.
Old Feb 12, 2007 | 01:08 AM
zo6chik's Avatar
zo6chik
not good....
Old Feb 12, 2007 | 03:13 PM
Dave68's Avatar
Dave68
There will almost always be some pad deposits on the rotors; however, if your braking performance is suffering, I'd recommend going back to OEM or Hawk pads. Also, remember that drilled rotors will eventually crack, so keep an eye on them.
Old Feb 12, 2007 | 03:54 PM
Bluefire's Avatar
Bluefire
If the pedal is spongy, you might need to bleed the system.
Old Feb 12, 2007 | 04:32 PM
AU N EGL's Avatar
AU N EGL
Pad deposit on your rotors is GOOD. After rotors are bed in properly, they should be a blue, purple, indgo color from the heat.
If they are shinny, they have not been bed in properly.
With any drilled and slotted rotor you will have dust. That is what the slots are for, to scrap the pad and keep it clean and free from glazing.
Yes it sounds like the brakes need to bleed again. IF you did not put in fresh DOT 3/4 or 4 brake fluid when you changed the pads and rotors, now is the time to do that.
Good Luck
Old Feb 12, 2007 | 04:53 PM
Hvymtlc5's Avatar
Hvymtlc5
Do you think it will hurt to put the used Ceramics back on? Will they seat properly?
Old Feb 12, 2007 | 05:36 PM
AU N EGL's Avatar
AU N EGL
Ceramics? wellll I am not too found of not being able to stop. IMHO cermamic brake pads have only one use, paperweights.
Keep the pads on you have. Just change or bleed your brake fluid.
Old Feb 12, 2007 | 07:09 PM
JEEP/C5's Avatar
JEEP/C5
Also, remember that drilled rotors will eventually crack, so keep an eye on them.[/QUOTE]
Not always - I have use cross drilled & slotted for years on the street and off road (in my Jeep Wrangler!) for years and never had one crack yet. On track or if you ride your brakes then maybe.
Old Feb 12, 2007 | 07:29 PM
AU N EGL's Avatar
AU N EGL
Not always - I have use cross drilled & slotted for years on the street and off road (in my Jeep Wrangler!) for years and never had one crack yet. On track or if you ride your brakes then maybe.[/QUOTE]
All rotors crack, D&S sooner then plain side. The hole is the start of the stress point. On the street, no need to worry.
Old Feb 12, 2007 | 10:35 PM
Dave68's Avatar
Dave68
Well that depends upon how you drive on the street. I know at least one CF member who has had cracked D/S rotors from street driving - be safe and stay away from them, especially the cheap ones.
To Rotor Glaze Question
