Tire Pressure Sensor
Old Feb 16, 2007 | 11:24 PM
mikeenticer29's Avatar
mikeenticer29
Default Tire Pressure Sensor
I have one sensor that is bad and it is my right rear tire. Is there anyway I can disable this sensor without repairing it. I still have about a years worth of tread left but if there is no way to disable I have no problem replacing it if needed.
Thanks for your help in advance
Mike
Old Feb 16, 2007 | 11:27 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
You'll have to continue to reset / ignore the DIC messages..
Old Feb 16, 2007 | 11:37 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
If you still have run flats on the car without the monitoring of the tire sensor you will not know when you have a flat and leave yourself open to a dangerous tire failure. My suggestion is to make the Gene Culley hookup and bring the system back to full function. I would want the system to operate even if I had non run flats on the car if for no other reason that it's in the car and functioning at 75% now.
Old Feb 17, 2007 | 12:09 AM
mikeenticer29
What is the Gene Culley hookup? I am new to this one.
Old Feb 17, 2007 | 12:16 AM
Ol'55's Avatar
Ol'55
Check out Gene at www.gmpartshouse.com
To Tire Pressure Sensor
