Pull Key Out, Wait 10 Seconds
Old Feb 20, 2007 | 01:44 PM
glerma's Avatar
glerma
St. Jude Donor '05
Default Pull Key Out, Wait 10 Seconds
What does this message mean? Everthing is working fine... It did this after I started it yesterday. I shut down... Restarted... no problems. Should I be worried?
Old Feb 20, 2007 | 02:20 PM
bighank's Avatar
bighank
Default Dirty ignition key resistor pellet
Probably the cause for this msg. Clean key pellet with alcohol and see if it fixes the problem. BIGHANK
Old Feb 20, 2007 | 03:19 PM
Nyvetteguy007's Avatar
Nyvetteguy007
Could be the dreaded column lock issue rearing its ugly head...much has been written on this topic, check the sticky at the top of the C5 tech pages under steering column lock FAQ's
Old Feb 20, 2007 | 03:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The resistor pellet in your key is a pression resistor and the BCM looks for that exact resistance! If the key is dirty or the contacts inside the ignition switch is dirty, it will tell you to basicly reinsert the key to make a better connection. The next time it does it, ignor it and try to move the car! The engine will shut down!
Recommend that you clean the old key with alcohol, use your spare key or get a new key. Sometines, you will need to get a ew ignition switch tumbler set.
BC
Old Feb 20, 2007 | 03:41 PM
DeeGee's Avatar
DeeGee
BC
And if that fails buy a column lock bypass kit.
Old Feb 20, 2007 | 03:42 PM
Nyvetteguy007
Old Feb 20, 2007 | 05:12 PM
GREG O.'s Avatar
GREG O.
Default message
happened to me yesterday after i had disconnected the battery for about 3 days. i hooked it up and when i went to start it up. that message came up. i thought it was because i had the battery on a slow trickle charge??? Guess i better get the alcohol out and start cleaning.
Old Feb 20, 2007 | 07:09 PM
65GGvert's Avatar
65GGvert
What year is your car? Your profile says 95. If you have a newer model automatic, you don't need the bypass kit. Update your profile if it's changed.
Old Feb 21, 2007 | 07:13 AM
Nyvetteguy007
Ahhh good question, if thats so he would be in the wrong forum (but there is a red C5 pic in his post)
Glerma, C5's have the column issue not C4's
To Pull Key Out, Wait 10 Seconds
