Tire Rot????
Old Feb 28, 2007 | 08:07 PM
whiplash 1's Avatar
whiplash 1
Default Tire Rot????
I am looking at a set of Goodyear Runflats that were on a 98 and removed back in 99 and stored in a garage with less than 10,000 mi. on them. My question is will the rubber deterioate on these since they have been stored for 8 years and become unsafe?
Old Feb 28, 2007 | 08:38 PM
DefenderC5's Avatar
DefenderC5
It's not a good idea to ride on tires that have been sitting that long. Usually the tire gets very hard and looses flexibility. It will start to develop stress cracks very quickly. Tires have a shelf life, but it varies per tire.
If it were me, I would get new tires... not worth risking my life over.
Old Feb 28, 2007 | 09:28 PM
Blown 346's Avatar
Blown 346
If the tires are in a garage where the temps vary form hot to cold, moisture etc, they can dry rot within a years time. I would pass on those for safety etc.
Old Feb 28, 2007 | 09:40 PM
whiplash 1's Avatar
whiplash 1
Let me get this straight a tire will dryrot in a years time??? There are a lot of bad tires out there!!!!!
Old Feb 28, 2007 | 09:44 PM
Weapon-X's Avatar
Weapon-X
Depends on how they were stored. If they coated with a silicone based protectant and individually bagged, they should be fine.
Old Feb 28, 2007 | 09:55 PM
Bill Dearborn's Avatar
Bill Dearborn
They are also run flat tires so dry rot in the normal sense probably isn't as big of an issue. The dry rot affects the rubber. With the run flats you could have a hole in them the size of a half dollar and the tire would not be flat. I would prefer them without dry rot but back in 99 I actually wore out a set of GY EMTs that I bought used after sitting on a loading dock in the hot Georgia sun for 2 years and they had some dry rot when I bought them.
Bill
Old Feb 28, 2007 | 11:19 PM
BowTieRocket's Avatar
BowTieRocket
One of my friends who farms, and thus has old tractor tires around, looked into this a while back. He came up with a statement from Michelin (I think - big tire company, and Michelin sticks with me) saying that something like five to eight years was their recommendation for changing tires if they don't wear out. They just begin to deteriorate.
The tires on my Shelby have been on it for 15 years or more. They aren't cracking, but the rubber has gotten really hard. When you do a burnout with it, it leaves powder instead of black marks on the pavement. BFG Euro T/As, so they had a fairly soft compound to begin with.
If in doubt, check with a local independent tire shop, and take a sample with you. In a nearby city, a guy named Bob owns one. His slogan is "Less Schwab - More Bob!"
Old Feb 28, 2007 | 11:45 PM
Dave68's Avatar
Dave68
The general rule of thumb is 6 years before getting rid of the tires. However, as Bill mentioned, runflats really cannot lose control during a blowout, at least not easily. Still, they are probably even harder than they were when they were new, so you are in for some kidney pulverizing!
Old Mar 1, 2007 | 07:50 AM
Oldvetter's Avatar
Oldvetter
6 years IS the industry standard, but how they are stored matters. Out of sun and away from electrical motors (ozone) helps. Bagged is best (but who does this?).
Old Mar 1, 2007 | 09:01 AM
Mr. Jones's Avatar
Mr. Jones
6 years
I have two front RF from my 2003 if your interested PM me.
Old Mar 1, 2007 | 09:47 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
My original run-flats will be 8 years old this summer. They do not have a crack on them.
Old Mar 1, 2007 | 12:52 PM
99 vett babycar's Avatar
99 vett babycar
I do
Old Mar 1, 2007 | 01:23 PM
Lancer033's Avatar
Lancer033
they're runcraps, put them on the car, do a nice smokey burnout until you hear the cords, then get some real tires on there
Old Mar 1, 2007 | 03:00 PM
BowTieRocket
Neither do my 15+ year old Euro TAs, but I don't trust 'em. Garage kept, dressed a couple of times a year, NorCal Mediterranean climate, but they've just gotten hard. Problem is, I need Coker replicas for the car shows, and those dudes cost as much as my Corvette tires...
I keep telling my friends, at 25+ MPG, under $20k to buy, long maintenance cycles, and under $500/year to insure, the Vette is an economy car. Who knew? :
Old Mar 1, 2007 | 03:18 PM
Rob Petyo's Avatar
Rob Petyo
every once and a while I wish I had a set for smoking..
To Tire Rot????
