Tin can rattle
Old Aug 28, 2007 | 04:37 PM
Z06Electron's Avatar
Z06Electron
Originally Posted by LF97C5Vette
Mine is not just a consistent ticking - like a consistent or rhythmic noise... it's sporadic, and the ticks will sometimes be back to back - or spread out by a couple seconds...
Almost always gone above the 1600RPM range -but for the first time - a week ago, i heard it at WOT in 3rd gear. From like 3k to 5.5k i heard 4-5 Ticks, that were audible above my B&B Bullets and DTE Supermaxx LTs...
If it's detonation - what should i do to start fixing it? What causes this? Would i be able to easily diagnose detonation on a Dyno?
-Dan
There is almost no way it's detonation unless one of the following has occured
You run lower than premium gas
Your car had an aftermarket tune that got too aggressive
You have a malfunction in your sensors or computer.
Long tube headers usually make yuor car run richer, making it even harder to get detonation on a stock tune.
Scanning software would tell you pretty quickly, you don't need a dyno, just something that measures A/F
Old Sep 12, 2007 | 10:15 PM
wildcatgs's Avatar
wildcatgs
i have the same tin can noise only when in gear hitting the gas light or hard. goes away if you let off the gas or hit the brake. car is a 97 auto all stock. had the car on a lift today cant duplicate the noise has to be on the ground with restriction. no noise if not in gear or if you try to power brake it . changed plugs and wires thinking it was a ping no diffrence. everything seems tight under the car. is there a way to check the cats? they seem ok when you bang on them . need help out of options
