Column Lock
Old Mar 26, 2007 | 08:08 PM
LS1 REDBIRD's Avatar
LS1 REDBIRD
Default Column Lock
Been driving with the column lock error messege for a six weeks now. Steering wheel has never locked up. I have to clear the messege everytime I start the car and it is getting annoying. Should I be fearfull?
Old Mar 26, 2007 | 08:28 PM
mitchcole's Avatar
mitchcole
have any of the recalls been done to this car?
Old Mar 26, 2007 | 11:40 PM
LS1 REDBIRD
I dont know, bought the car 8 months ago from a private party in Oakdale.
Old Mar 27, 2007 | 10:15 AM
87SAM's Avatar
87SAM
Can you turn your steering wheel with the ignition off?
BTW, I'd be worried, but that's just me.
Old Mar 27, 2007 | 10:18 AM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
CLB is your friend...
Old Mar 27, 2007 | 11:25 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,check and see if you can turn the wheel with the ignition OFF and key removed. If you can, you have has some of the recalls done or you already have a CLB. Check your DTC's. If you have any BCM or PCM DTC's as history, you will need to clear them!
If you dont know how to read your own DTC's,,go to this website:
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Something else that will effect the Column lock operation is a low charged or bad 12 VDC battery. make sure your battery is fully charged and working correctly. Have it tested at AutoZone.
BC
To Column Lock
