auto question
Old Apr 17, 2007 | 09:16 PM
nmbis2k's Avatar
nmbis2k
spins sideways??? sounds like just the right amount of power.
Mine will step out to the left a little, depending on road surface.
Yet to get sideways.
Old Apr 18, 2007 | 01:11 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by DavzC5
A4 stock car will not spin the tires or go out of control when you floor it going 40 mph. I know, I've tried it.
Mine does all day with the 3:15s ......And chirps 2nd and 3rd.
Old Apr 18, 2007 | 04:57 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
Damn, I wish mine car did that! Guess it's time for some 3.42's and some other mods.
Old Apr 18, 2007 | 10:40 PM
tsts's Avatar
tsts
Default Keeping it straight
Got a '99 stock with TI exhaust, A4, 3:15 rear gears, and a CoW tune from Chuck. It will burn about 8 feet and feels a little squirly when it does the 1-2 shift after punching it off the line (about 30 foot burn there). Using Goodyear D'3s. When i'm in 4 gear, driving normal then punch it to WOT the engine picks up too much RPM when it gets back to first gear and I get what you describe. The cure's are try to be in second gear (or at least 3rd) before you WOT backshift to first, it doesn't come as strong and it can be managed. Even more important, don't be doing this when rolling around someone on a pass and don't be on a curved road, you'll have too roll out with a little throttle and get alligned straight then hit WOT and you should be able to keep it straight. My trans also has non-stock settings for throttle pressure, torque management, and raised shift points (RPM) . All this is with TC off, not in Performance Mode.
