auto question
Old Apr 16, 2007 | 06:29 PM
bobharp's Avatar
bobharp
Default auto question
When driving my 2000 coop at 40mph, if I floor it the car spins sideways out of control. Anybody have this problem? It's an auto.
Old Apr 16, 2007 | 06:37 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Sounds like your traction control is either off or not working correctly.
Old Apr 16, 2007 | 07:02 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
So where is the problem Turn the traction control back on and have fun
Old Apr 16, 2007 | 07:07 PM
MannyFresh's Avatar
MannyFresh
Yeah that happens to me also but a second later the traction control kicks in.
Old Apr 16, 2007 | 08:57 PM
torchvette10's Avatar
torchvette10
I love that! That's why my TC is always off!!!!!!!!
Old Apr 16, 2007 | 08:59 PM
racetchr's Avatar
racetchr
Welcome to Corvette World
Old Apr 16, 2007 | 09:01 PM
glassman15's Avatar
glassman15
If you dont like it buy a geo!
Old Apr 16, 2007 | 09:04 PM
old stingray's Avatar
old stingray
Problem?
Old Apr 17, 2007 | 12:06 AM
Wake Champ's Avatar
Wake Champ
Does it have higher gearing, or a higher stall Torque Converter? Or like someone mentioned, maybe your traction controll is not working correctly.
Old Apr 17, 2007 | 12:25 AM
Bluefire's Avatar
Bluefire
Oh-oh! mine does that too!
Old Apr 17, 2007 | 01:43 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
A4 stock car will not spin the tires or go out of control when you floor it going 40 mph. I know, I've tried it.
Old Apr 17, 2007 | 02:01 AM
SLPRC5's Avatar
SLPRC5
3:15 or 3:42s will....mine does and it chrips the rear wheels too
Old Apr 17, 2007 | 01:31 PM
DashingDaryl's Avatar
DashingDaryl
Does your DIC ever display TRACTION CONTROL ACTIVE during/after this?
Old Apr 17, 2007 | 04:08 PM
pdgourno's Avatar
pdgourno
When did "sideways" become "out of control". I call it cornering.
Old Apr 17, 2007 | 04:27 PM
DeeGee's Avatar
DeeGee
Cutting through the flames here
If the TCS is working it really should counteract that. Do you have any DIC codes? That may tell you if there's a TCS problem. And, do you have active handling?
Old Apr 17, 2007 | 04:32 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
me too
Old Apr 17, 2007 | 06:43 PM
Laguna Blu's Avatar
Laguna Blu
Sounds like waaay too much HP with some lousy rear tires.
To auto question
Old Apr 17, 2007 | 07:04 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
If the traction control doesn't act fast enough to stop it from spinning another way to reduce the spinning at upshift or downshift is to add % to the torque management---Most people take most of it out to give them some extra kick however on some cars--especially modded ones some should be left alone or increased--For example on my modded '98 A4 when drag racing I have to add about 10% above the stock setting in 1st to keep it from spinning itself out--Stock is about 28% and I kept adding % until it just barks them a touch-- Ended up about 36%--At 1st when i had it at the stock setting--it spun out and i just missed backing it into a tree at the 1-2 shift !!!!------Be careful--
Old Apr 17, 2007 | 07:16 PM
4DRUSH's Avatar
4DRUSH
It's more Fun at 100 MPH
Cold roads & Run craps is my guess why you are spinning
Old Apr 17, 2007 | 08:49 PM
Jharms's Avatar
Jharms
Yes, it's the tires. I've gone through a few sets. Worn tires easily cause the rear end to go out of control when punching it at 40 MPH.
If you've got this problem, it will also spin the tires when shifting from 1st to 2nd when keeping it floored. It gets really exciting when you're going around a slight curve during the shift.
