C5 Over Heating
Old May 10, 2007 | 08:59 PM
Jeff48's Avatar
Jeff48
6th Gear
Default C5 Over Heating
Out of the blue my 2002 covertable overheated with out even getting on it excessively. Replaced thermostat still over heating. I have an appointment with a dealer next week for the continual Active Handling off-on problem as well (code C1287 or C1288). The overheating is another new one. I'm bummed out! Any one know anything here?
Old May 10, 2007 | 09:22 PM
951driver's Avatar
951driver
To jump in a bit here. What is the "normal" operating temps that people are seeing? Is 220 really the middle of the range? At what temps so the fans turn on? I have an 02Z.
Old May 11, 2007 | 12:52 AM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
I recently started experiencing hotter run temps myself. Cruising down the hiway, mid 60' ambient temp and the car is seeing 220 plus ? A stuck thermostat would cause this I assume. It just seems weird... My temps are all over the map. I am hoping it is simply a faulty temp sensor... Going to the dealer soon... ugh ...
Old May 11, 2007 | 01:13 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
http://forums.corvetteforum.com/show....php?t=1691619
See reply# 5
BC
Old May 11, 2007 | 01:26 AM
RED99's Avatar
RED99
You need to clean out the front of your AC condensor. The C5 is a bottom feeder, and will suck up everything on the road. Driving in the Fall when the leaves are all over the road is like using your car for a street sweeper.
Old May 11, 2007 | 02:06 AM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Originally Posted by Bill Curlee
Yup, appreciate it. I will be cleaning things up tomorrow. Although the radiator looked clean last check under the car, I will be cleaning things up just to be sure.
Old May 11, 2007 | 06:54 AM
AU N EGL's Avatar
AU N EGL
I clean my radiators out before each track weekend, about once a month, it is amazing how much stuff gets sucked up into there.
They may look clean, but taking a high pressure air hose blows out all the dirt, sand, small grass and micky D bags and dead miatas that were sucked up into that area.
Old May 11, 2007 | 05:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a space between the radiator and the AC Condensor that you really need to examine carefully. When we installed englandgreens cam, we pulled the radiator out and that area had enough dead grass to feed a good size goat! It was also full of very find sand!
I have had good success removing the plastic cover on top of the two radiators and examining the area. Then back flush with a full stream shot of the hose.
BC
To C5 Over Heating
