Alright let us see if someone here can help me with my recent issue. I installed a HID kit by LEDGUAGES which included two ballasts and 4 weatherproofed quick-connect connectors. No splicing was done to any of the wires. I am having intermittent problems with my blinkers. Sometimes they will work and sometimes they won't on the road. When I first turn the car on that is the first thing I check right now and about 8/10 they do turn on. Once I get going they come in and out. They only blink when they want AND I have the blinkers set to either right or left. I tried seeing if the hazard button would turn them on, but I think they must go through the same circuitry, because they wouldn't come on as well. Is it possible that I have a relay sticking? What do you guys think?
It is probably your hazard switch. It is a very common problem on these cars. Next time they do not work, press the hazard button several times, if they start working again, you have found your problem. There are many how to instructions on the forum to replace the switch. It is about 30 bucks and takes an hour to do.
Thanks for the quick response, both of you. Could I impose a little more and ask for a link to such how to do doc? I buy you a beer if you ever in town haha
I cant find the thread but I copied it into a word doc
