LS6 Rocker Arm Torque??
Old May 12, 2007 | 08:53 PM
427CPE's Avatar
427CPE
Default LS6 Rocker Arm Torque??
Got in to a little project this weekend. Anyone know the torque spec on rocker arms and valve covers?
Thanks.
Old May 12, 2007 | 10:11 PM
ZSS2148's Avatar
ZSS2148
I do 22 on the rockers and just tighten the covers by hand....
Old May 12, 2007 | 10:40 PM
427CPE's Avatar
427CPE
roger that. i just came from a test n tune run, thanks.
Old May 12, 2007 | 11:37 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
ft/lbs
Old May 13, 2007 | 12:06 AM
Fast@50's Avatar
Fast@50
Default reply
spec. is 22 ftlb and the order doesnt mater. Valve covers are 10 newton meters just start in the center and work your way out.
Old May 13, 2007 | 07:55 AM
davidfarmer's Avatar
davidfarmer
all torque specs
http://www.davidfarmerstuff.com/C5torque.pdf
Old May 13, 2007 | 08:25 AM
vettenuts's Avatar
vettenuts
22 lb-ft on those rockers on whose lifter is on the base circle, rotate crank one turn and do the others.
Old Sep 5, 2007 | 10:20 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Just the information I was looking for. Gonna add this to the bookmarks.
To LS6 Rocker Arm Torque??
