Transmission Jack
Old May 18, 2007 | 09:11 PM
corvettedoug's Avatar
corvettedoug
Default Transmission Jack
What is everyone's opinion on buying an ATV Jack to use as a transmission jack?
Sears has one for 90 bucks which is in between the price of the cheaper transmission jack at harbor freight (60 bucks, 450lbs) and the more expensive 140 trans jack(800lbs) at harbor freight. The ATV jack holds twice the weight it appears.
http://www.sears.com/sr/javasr/produ...cemldffidfno.0
Old May 18, 2007 | 09:15 PM
vettenuts's Avatar
vettenuts
It will work. The only thing I like about the Harbor Freight jack is that it is a scissors, so I am hoping I have a little more fine adjustment with it.
Old May 19, 2007 | 01:11 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
The cheaper screw / scissors Harbor Freight jack is marginal for this application..
I did borrow one from a bud to R&R my rear end during my gear swap (the jack was brand new), but it's load capacity was obviously taxed, refusing to raise / lower smoothly with a load on the jack.
When I needed to R&R the trans out of my wife’s Corolla to swap the clutch, I bought the more expensive HR hydraulic version; highly recommended.
Old May 19, 2007 | 07:16 AM
vettenuts's Avatar
vettenuts
There is no question you get what you pay for, and I don't go under the HF jack. I did find that liberal grease on the jacking screw helped a lot with the smoothness.
Old May 20, 2007 | 10:57 PM
EaglesNest's Avatar
EaglesNest
I bought a 1000 Lb jack from Grizzly for the same price as the 800 Lb one from Harbor Freight around 135.00. It worked great and I was able to change my clutch by myself, It had tilt front to back and side to side. The only thing I had to add was a nylon cinch strap instead of using the cheap chain that came with it. It held the whole assembly stable with out a problem.
Old May 20, 2007 | 11:56 PM
RED99's Avatar
RED99
I just bought and used the El Cheapo harbor freight jack, and it worked great. The thing I like about it the most is it's not hydraulic. So there is no bleed down from a leaky cylinder. And it's a scissor jack, so it lifts straight up and down. Can't beat it for the money. If I was going to take a lot of trannys out, I would get something more professional. But for something that I hope I will only need once or twice, it works good enough.
Old May 21, 2007 | 01:28 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
100%
Old May 21, 2007 | 06:30 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I got this from Northern on sale for the same price........
I like it for the adjustment, I did my own A4 R&R by myslef on the 97' w/o issues using this jack
http://forums.corvetteforum.com/show....php?t=1582390
To Transmission Jack
