what cam?
Old Jun 19, 2007 | 11:23 PM
98tripleblack's Avatar
98tripleblack
Default what cam?
hi i am looking for info on what cam to use for my 98. i am doing headers and i will also continue to be spraying a 150 wet shot. car is a daily driver, any input would be appreciated
Old Jun 20, 2007 | 10:11 AM
BLOWNTRC5's Avatar
BLOWNTRC5
I also running a 150 shot. The cam I have here is a
Comp 228/232 588/ 595 on a 110+2 LSA. If I remember corectly it only has 4 deg. of overlap.
Doug
Old Jun 20, 2007 | 04:49 PM
kilrb's Avatar
kilrb
Doug
A cam with those specs is going to have 10 degrees of overlap. 228+232 = 460 / 4 = 115 - 110 = 5 x 2 = 10
Old Jun 20, 2007 | 05:06 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
get my cam..224/228@114
Old Jun 20, 2007 | 06:52 PM
fearless's Avatar
fearless
I have a 2000 model, bone stock with a 6 speed. Would a cam be a wise investment for my car and what kind??
Old Jun 20, 2007 | 07:02 PM
BLOWNTRC5's Avatar
BLOWNTRC5
Yep your right, sorry about that!! Thats what I get for not redoing the math before I post!!
Doug
Old Jun 20, 2007 | 09:30 PM
98tripleblack
thanks for the advice guys, is there any particular brand you would reccomend. as of right now i was thinking comp. and what kind of power did you guys pick up?
(fearless) yes the cam is a good investment, with headers you can get a good amount of horsepower for the money.
Old Jun 22, 2007 | 09:22 AM
kilrb's Avatar
kilrb
I certainly hope so; I did it on my 1999, and I'm basing my retirement on it!
If you do consider a cam, go spend a couple of months reading and learning before deciding which way to go. You'll most likely regret it if you just ask people what cam to get. Your choice will not only affect peak power, but where the power is (rpm range), idle, driveability, lope, etc. It's a highly personal decision IMO.
Old Jun 22, 2007 | 09:32 AM
vettenuts's Avatar
vettenuts
Couldn't agree more. I made my selection based on where I wanted the power, the drivability so my wife would still be able/want to drive it, emissions, etc. etc. etc. There is a tech article on Popular Hotrodding's web site called "Be the Cam Expert" written by David Vizard, this makes a very good primer to help you select the parameters.
To what cam?
