lean vs rich cylinders
Old Jun 20, 2007 | 10:32 AM
billiardcue's Avatar
billiardcue
Default lean vs rich cylinders
Which cylinders on an LSx typically run the leanest, which run the richest?
Why don't both banks run the same air fuel ratio?
Old Jun 20, 2007 | 10:37 AM
dougbfresh's Avatar
dougbfresh
???? Why do you think some run leaner/richer than others?
Old Jun 20, 2007 | 11:02 AM
AU N EGL's Avatar
AU N EGL
#7 runs leaner. #8 has the least oiling and cooling around the cyclinder.
a good tuner can tune or turn up the A/F ratio of #7 without effecting the others.
#7 and 8 are the two problem cyclinders in the LS1, LS6 motors.
Old Jun 20, 2007 | 11:13 AM
dougbfresh's Avatar
dougbfresh
How would you know for sure without sampling exhaust gas seperatly? Maybe EGT on each cylinder?
Old Jun 20, 2007 | 11:15 AM
Smoove
Guest
Posts: n/a
Yes, EGT each cylinder. Or you can just base the tune off of #7. Like someone above already said(i think).
Old Jun 20, 2007 | 11:23 AM
billiardcue
Most engines typically have cylinders that run leaner or richer than the rest due to the intake manifold design, throttle body position, etc.
I would assume that cylinders 7 & 8 run the richest as they are furthest from the throttle body.
Bought new injectors and they are flow rated so I figure I'll match them to the motor's inherent properties.
I know that the left bank runs leaner as I have two wideband O2 sensors.
Old Jun 20, 2007 | 11:36 AM
billiardcue
How do you do this?
I use EFILive.
Old Jun 20, 2007 | 11:43 AM
dougbfresh's Avatar
dougbfresh
Can you adjust injector pulse width individually?
Old Jun 20, 2007 | 11:59 AM
vettenuts's Avatar
vettenuts
I had my injectors cleaned and flowed. I put the two that flowed the most in 7 & 8 as a precaution since I knew the numbers.
Old Jun 20, 2007 | 12:43 PM
FRCTony's Avatar
FRCTony
Not with the stock PCM.
Old Jun 20, 2007 | 02:27 PM
dougbfresh's Avatar
dougbfresh
SO, that would mean adjusting a single cylinders A/F ratio would not be possible with a stock PCM?? I would think it's an all or nothing proposition with the stock computer.
Old Jun 20, 2007 | 02:35 PM
blkvett01's Avatar
blkvett01
I might be wrong but in HP tuner you can adjust the table by left bank and right bank. In the table map i saw adjustment for that but not sure about each injector i think it is left and right, just like the o2 sensor read left anf right bank.
To lean vs rich cylinders
