Brakes Pulsating
Old Jun 28, 2007 | 03:57 PM
Z-THREAT's Avatar
Z-THREAT
Default Brakes Pulsating
Brakes are giving a pulsating feel when applying. Do you think it is the rotors? That is my first guess. Any input would be greatlly appreciated.
Best Regards-
John
Old Jun 28, 2007 | 04:02 PM
87SAM's Avatar
87SAM
Certainly sounds like it could be warped rotors.
Old Jun 28, 2007 | 06:24 PM
Showdown's Avatar
Showdown
my drilled rotors did that right before they started cracking
Old Jun 28, 2007 | 06:44 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
If the car hasn't been really driven hard, I believe Stoptech has the answer.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Jun 28, 2007 | 07:45 PM
FRCTony's Avatar
FRCTony
It's usually uneven pad material. You can take them off and clean them to find out.
Old Jun 28, 2007 | 08:03 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Very good reading.
Old Jun 28, 2007 | 08:12 PM
Bob CTS's Avatar
Bob CTS
That is a bunch of information, informative reading.
Old Jun 28, 2007 | 08:32 PM
Z-THREAT's Avatar
Z-THREAT
How do you clean? Is it that evident when you inspect them?
Regards-
John
Old Jun 28, 2007 | 08:59 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
Because of the relative light weight of the C5 rotors it is imperative that you use a torque wrench and torque your wheels exactly like FSM describes.
If you don't follow the directions you will physically warp your rotors which you may have already done. Try retighening them correctly.
Old Jun 28, 2007 | 11:18 PM
vms4evr's Avatar
vms4evr
Regards-
John
No it's not evident. The uneven build up, if that's your problem, is not visible. Take some 100 grit or so sandpaper on a sanding block and give them a good scrub. It would be easier to remove them to do it. But if you don't know how then scrub both side and turn the rotor by hand. Then go follow that stoptech brake pad bed in process. If they still pulse badly then time for new rotors.
Old Jun 28, 2007 | 11:27 PM
Smokin Joe's Avatar
Smokin Joe
SERIOUSLY, this is important to read. If re-bedding your brakes doesn't work you can turn the rotors and replace the pads. I just swapped rotors for napa rotors, very cheap, search my screen name for archives and you'll pry find the part numbers. The swap was cheaper than I finding someone to turn the rotors.
Old Jun 28, 2007 | 11:30 PM
Smokin Joe's Avatar
Smokin Joe
AGAIN, read the stoptech article...but "warping" aside. I spoke to one of the GM engineers at Vettes on the Rockies a few years ago, and he told me it was very important to torque the rotors. His exact words were to torque the rotors in a star pattern, 30, 60, 90, 100 foot pounds. Believe it if you want. I always torque the wheels onto any car, but I prescribe to the stoptech article.
READ the stoptech article.
Old Jun 29, 2007 | 03:22 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Good reading (read it a few years back), but unfortunately I've never been able to stop pulsating via bedding or cleaning once it's started.
Resurfacing costs as much or more than a new set of rotors.
Old Jun 29, 2007 | 09:43 AM
bighank's Avatar
bighank
Default pulsating brakes
Make about 10 or 15 HARD STOPS from say 70 or so down to 20 MPH to really get the brakes HOT. DON'T KEEP THE PEDAL ON TO A COMPLETE STOP OR YOU WILL GET MORE BRAKE MATERIAL ON THE ROTORS. Most rotors AREN'T WARPED just have some brake residue on them. Super hard braking can remove most of that material. BIGHANK
Old Jun 29, 2007 | 10:25 AM
BQuicksilver
I do plenty of HPDE's, and have bedded more than my share of pads. The Stoptech method just hasn't worked for me, and new rotors are cheap.
Old Aug 11, 2008 | 10:08 AM
Black 79's Avatar
Black 79
My car occasionally pulsates just before it stops. I don’t drive the car hard so it is likely buildup as described in the StopTech article. My ‘cure’ has always been to make one medium hard stop and it brakes smooth for a while. This probably only works for cars that aren’t driven hard, but for daily drivers used for transportation like mine it seems to do the trick.
Old Aug 11, 2008 | 03:56 PM
Dave68's Avatar
Dave68
Slamming the brakes is only temporary at best. The only permanent solution if you'd like to continue to use the excellent OEM pads is to replace the rotors with slotted versions. I bought PowerSlot rotors a few years ago and have not had any pulsating brake pedal issues, since.
To Brakes Pulsating
Old Aug 11, 2008 | 05:59 PM
lionelhutz's Avatar
lionelhutz
I would either get the rotors cut or install new ones. Make sure you clean the rust off the mounting surfaces so they mount true. I've gone 6000 miles since surfacing mine and the brakes are still excellent. I'm lucky since I can borrow a brake lathe and do them for free. I did the ebrake drum too so it works great now.
I've put my S10 one piece hub and rotor onto the lathe using the bearing races to mount it and it had run-out indicating a warped rotor. The vette rotors seemed more to be just uneven but I didn't check them really, just cut them and went.
Peter
Old Aug 11, 2008 | 06:56 PM
Black 79's Avatar
Black 79
Default PowerSlots
One of my sons has a hotrod Mustang with a Brembo / PowerSlot combo that has been working great for several years. I drove the car myself for a while and the were flawless.
David.
Old Aug 11, 2008 | 09:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
On my '99, I kept having the rotors getting warped. Had them turned more than once, replaced them once and always the problem kept coming back. Finally, I bought new rotors again and put on ceramic pads at the same time. No more problems following that.
