Need advice with Window wiper problem
Old Jun 29, 2007 | 10:13 PM
bliehr's Avatar
bliehr
Default Need advice with Window wiper problem
The wipers on my 97 have started going on and off by them self, and just stoping anywhere, and will not return home or at rest.
Sometimes they come on and run for a few minutes then just stop anywhere.
I have now pulled the fuse to stop them all together.
Is this a switch, ground, or relay problem? Nothing else seems to be wrong. Only the wipers.
I just purchased this car with 46000 mi on it and know next to nothing about these cars yet.
I have had 5 older vettes over the years
Any help or advice will be much appreciated.
Bob
Old Jun 30, 2007 | 09:50 PM
bliehr's Avatar
bliehr
Anyone think this may be a grounding problem?
Old Jul 1, 2007 | 12:05 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Mine does the same thing. I have checked all grounds. From my understanding it's the wiper motor itself, I just haven't replaced it yet.
Old Jul 1, 2007 | 09:18 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
clogged udders often kill wiper motors
Old Jul 1, 2007 | 09:28 PM
bliehr's Avatar
bliehr
What the heck is an udder!
Old Jul 1, 2007 | 10:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you dont know what an udder is,,,,,,,then it for sure could be your issue!
There are THREE of them in this area. Clean them out and flush out the cavity:
If there full of trash, it will flood out the control module and cause that issue.
BC
Old Jul 2, 2007 | 12:58 PM
Nyvetteguy007's Avatar
Nyvetteguy007
Bob
I hardly drive my car in the rain...was in a friggen monsoon last year, had the issue you describe...pulled the wiper fuse to stop them & cleaned out my udders, still had the issue, I put off replacing the motor (lazy) and was going to eventually do so.....waited about 4 months, decided to order the motor but before doing so I put the fuse in just to ck if it was still an issue...and guess what?? No issue...evidently it dried out enough to work OK...its been aOK for almost 6 months now....
Old Jul 2, 2007 | 01:44 PM
axikowboy's Avatar
axikowboy
Just did mine last week, I would recommend some gloves. Mine were pretty nasty. Thanks to Steve and Bill for their pictures, sure helped me out.
Old Jul 2, 2007 | 03:03 PM
Bville-Bud's Avatar
Bville-Bud
St. Jude Donor '05-'06-'07-'08
Here's the write up I did when I replaced my wiper motor. You can see the udders from the top view.
http://forums.corvetteforum.com/show....php?t=1715595
Old Jul 2, 2007 | 10:58 PM
bliehr's Avatar
bliehr
So that's what you call those areas and drains!
Hey, Thanks alot Guys for all the good info and pictures.
I knew I could count on the good people here to help me out Again.
Old Jul 3, 2007 | 07:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep! Udders Mooooooooooooooooooo!:d
Bc
Old Jul 6, 2007 | 09:50 PM
bliehr's Avatar
bliehr
Default Thanks Bill, Bville, and others:
Thanks for the info and great pictures.
They [the udders] were full of mud etc. I think I'll wate a few days and see if the motor dries out before I replace it.
That link to replacment will Really come in handy.
Thanks Again
Old Jul 6, 2007 | 10:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I removed mine and flushed it out with WD-40. That made te difference. Its worked fine since then.
BC
Old Jul 20, 2007 | 10:20 AM
bliehr's Avatar
bliehr
Default Changed Motor...... Thank You
Thanks for all the help and fine details on changing the wiper motor.
The Utters where the cause of the motor failure.
Purchased the motor at Auto Zone. $38.00 and core.
Following Bville-Bud's instructions, I changed the motor with no problems and works fine. Thanks much BB.
Cleaned out the utters and motor well.
Snipped the tip off the Utters to help drain well.
All is working great!
Thanks again Guys!!!
Old Jul 22, 2007 | 04:21 PM
leetownreb's Avatar
leetownreb
Default wiper problem
had the same problem. replaced motor and problem not fixed. still have the fuse out and am trying to find a shop to fix the stalk. udders were spotless, etc. maybe they have injected attitude into the wipers
To Need advice with Window wiper problem
