AC Delco Leaking...
Old Jul 2, 2007 | 07:44 PM
JCrouse's Avatar
JCrouse
Default AC Delco Leaking...
I posted recently in another thread about my car not starting. Turns out the problem wasn't a dead battery, but a butt-load of corrosion due to the positive cable. After removing the battery, there's a nice "field" of corrosion powder straight under the middle of the battery, all over what looks like a 2" diameter tube.
What's the best way for cleaning all this crap out of there, what do i need to look for as far as damage, and how do i prevent it from happening again? I'm assuming start with trashing the Delco even though it's still holding a good charge?
I tried searching, but didn't find exactly what i was looking for.
Thanks in advance.
Old Jul 2, 2007 | 07:53 PM
TEXHAWK0's Avatar
TEXHAWK0
I used to use baking soda to neutralize the acid, but now you can get a foaming acid neutralizer in a spray can. Permatex is the brand that I used. I think it even changes colors when it reacts with acid so you can tell if you got it all. Then flush the area with water.
The only sure way to keep it from happening again is switch to a top post battery. My 2004 model came with a top post battery, and you should be able to replace your cables with those used in 2004. If the cables are corroded, you will need to replace them anyway. The acid tends to run all the way down the cable, even inside the insulation. I would also check the starter connections to make sure the acid did not work its way down there.
Old Jul 2, 2007 | 07:55 PM
Bob CTS's Avatar
Bob CTS
Trash it for sure, notorious for this, as for neutralizing the acid use baking soda, remove battery, remove battery tray, rinse with water, sprinkle the baking soda to look for foaming (indicates acid) then rinse, rinse and rinse again. Dry it all and look for corrosion and if so sand and hit with some paint. Put everything back together.
Old Jul 2, 2007 | 08:06 PM
jordanfd's Avatar
jordanfd
Water and baking soda will neutralize the acid pretty darn good. Switch to Optima red top dry cell battery. about $165. bucks. Hope you haven't damaged the wires, connections or computer directly under battery. Frank
Old Jul 2, 2007 | 09:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The optima is NOT a dry or Gel cell. Its a spiral wound lead acid battery. Its uses a recombent gas recovery system to recoupe the gasses and its sealed to prevent acid spillage.
Theres a splice pack behind the battery. You will need to find it, take it apart and MAKE SURE that it doesnt have acid in it! If you dont, this is what will happen:
Heres the same one all cleaned up:
BC
Old Jul 3, 2007 | 12:32 AM
JCrouse's Avatar
JCrouse
I appreciate everyone's responses...looks like i have a little project for the 4th of July.
On a side note, is the Optima Red Top really worth the money over say a Duralast or other standard battery from an Auto parts store?
Old Jul 3, 2007 | 12:57 AM
Bill Dearborn's Avatar
Bill Dearborn
I just had my Delco AGM battery replaced with a new Delco non AGM battery. It looks like Delco has changed their battery case and may have strengthened the way the posts are fastened into the battery. The case looks like the case of the Exide battery I just installed in my Tahoe.
Bill
To AC Delco Leaking...
