Headlights dimming / pulsing
Old Jul 2, 2007 | 11:05 PM
minitech's Avatar
minitech
Default Headlights dimming / pulsing
I have a 2000 which is new to me. I don't have any experience with the c-5. I noticed when the headlights are on at night and I lower the windows there is a dimming of the lights for a second, not out but dimmer / pulsing with the window and use of power.
I also noticed the lights on the radio seem to pulse a little when idling at a light but then are fine with driving.
Is this an alternator problem? Normal? Can I fix it by installing a high output alternator?
No codes on this just a notation of finding.
Thanks minitech
Old Jul 2, 2007 | 11:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is pretty much mormal. There really isnt much that you can do to fix it. The PCM controls alternator output. If you swap in the wrong alternator, you will have DTC's The PCM is quite pickey on what it expects to see. As long as your seeing close to 13.8 to 14.5 during normal operations, your good. Temp and battery condition will cause it to read higher or lower at times.
I would however, remove the battery, inspect the area directly below the battery for acid spills, have the battery fully tested, clean the terminals (spray them out with brake parts cleaner and then WD-40) and reinstall the treminals. They must be torque to 11 ft/lbs to work properly. Too loose or too tight will cause issues.
What battery is installed?
BC
Old Jul 3, 2007 | 08:20 AM
Oldvetter's Avatar
Oldvetter
Great advice. Overtorquing the side terminals on batteries is one of the major causes of them leaking acid. Your computer is below your battery.
Old Sep 16, 2007 | 09:41 AM
minitech's Avatar
minitech
My problem ended up being a loose positive termainl on the battery. It also was causing a small flickering of the inside gauge and radio lights. all now fixed with a turn of the terminal nut.
To Headlights dimming / pulsing
