How to replace front turn signal?
Old Jul 10, 2007 | 09:55 AM
STLKillerC5's Avatar
STLKillerC5
Default How to replace front turn signal?
Hey guys! I had a front right turn signal go out. I was looking at replacing it last night and when I started looking at the car it seems like there's no easy access to replace the light. Is this complicated on this car? Do I need to remove some parts to get to it?
Old Jul 10, 2007 | 11:14 AM
DeeGee's Avatar
DeeGee
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
Old Jul 10, 2007 | 01:47 PM
STLKillerC5
Thanks Deegee! Luckily my guns aren't too big so hopefully I can squeeze my arm thru easily. I'll get it done tonight!
Old Jul 10, 2007 | 05:14 PM
EtidW's Avatar
EtidW
If your hand and arms are medium to small going through the brake duct is quick and easy took me about a minute. Either way you go there is a lock on the bulb housing that needs to be pushed in to allow the housing to turn. If you go through the brake duct the housing will pull out through so you can easily replace the bulb.
Good Luck
Old Jul 10, 2007 | 06:31 PM
vettenuts's Avatar
vettenuts
Key statement, last time I did this it took one minute to get my hand in and about 15 minutes to get it out
Old Jul 10, 2007 | 07:52 PM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
Last time I replaced bulbs I had to remove the bottom panel. The bulb holder was stuck. There are about five 7mm screws used to mount the panel.
Old Jul 10, 2007 | 08:09 PM
Bob CTS's Avatar
Bob CTS
Originally Posted by DBS99MagRedCoupe
Last time I replaced bulbs I had to remove the bottom panel. There are about five 7mm screws used to mount the panel.
That is what I did.
Old Jul 10, 2007 | 09:10 PM
corvettedoug's Avatar
corvettedoug
10 minute job.
I have found choice number three works best for me.
Old Jul 11, 2007 | 04:24 AM
David426's Avatar
David426
[QUOTE=DeeGee;1561011424]You'll get three suggestions
Been there done that. Quickest,easiest way without tearing skin off your hand/arm
Old Jul 11, 2007 | 05:27 AM
jodfit's Avatar
jodfit
St. Jude Donor '07
10 minute job.
And watch your language while you are doing this , you never know who will be around.
Old Jul 11, 2007 | 06:06 AM
robvuk's Avatar
robvuk
Going in through the brake duct? You know what they say about having small hands...
To How to replace front turn signal?
